07-18-2014, 02:05 PM   #1
Wireless P-TTL HSS using Metz 52 AF-1
To all Pentax Masters,
I am a newbie on Pentax, but not new to photography. I just bought my a Metz 52 AF-1 Flash for Pentax with the assumption that it can work as a Master or Controller or Slave using P-TTL & HSS in wireless mode.
However, when setting it up as the master or Controller on my camera, HSS is not an option, and my shutter speed is limited to the highest X-sync speed. To eliminate the camera is a factor, I set the flash to slave, and my only two option for the flash mode are still limited to P-TTL or Manual.
My understanding is that the new Pentax flashes can operate wireless P-TTL with HSS, but those flashes are expensive. Any suggestions?
07-18-2014, 05:53 PM   #2
HSS is a flash feature that is supported by the camera. Check your manual for how to configure the flash for HSS. You should be able to use HSS in Tv and M modes.
07-18-2014, 06:39 PM   #3
Kozlok's Avatar
From what I remember, the Metz will do HSS as a slave, but not a master. For HSS you need a Pentax flash on the camera. Get a used AF360, usually only around $125 or so. Of course watch out for the battery door on those, they're junk!
07-18-2014, 10:33 PM   #4
Thank you Kozlok, I'll check that out =D
07-19-2014, 12:09 AM   #5
QuoteOriginally posted by chobit Quote
Any suggestions?
I think the Sigma DG Super flashes (EF-530 DG Super, EF-610 DG Super) may do HSS sync in controller mode. At least the Pentax TTL Flash Guide doesn't say they won't.
07-19-2014, 02:47 PM   #6
Kozlok's Avatar
Looks like there is a firmware upgrade to allow HSS with the K-30 and K-5"
https://www.metz.de/en/flash-units/firmware-download-flash-units/mecablitz-4...al/pentax.html
camera, controller, flash, flashes, hss, hss using metz, option, p-ttl, p-ttl hss, pentax, pentax help
Overexposed P-TTL when using Metz flash Maksat Tutan Troubleshooting and Beginner Help 17 05-06-2014 01:49 PM
Strange Happening Wth Metz Flash In P-TTL/HSS. tabl10s Pentax K-3 11 04-05-2014 12:05 PM
For Sale - Sold: Metz 50 AF-1 P-TTL Flash for Pentax Heie Sold Items 2 11-12-2013 11:48 PM
Metz 58 AF-1 & 48 AF-1 differences, plus other P-TTL guns Richard Day Flashes, Lighting, and Studio 14 12-22-2010 09:24 AM
All times are GMT -7. The time now is 08:08 AM. | See also: NikonForums.com, part of our network of photo forums!
