The D mount lenses should work too given the tiny sensor on the body. I am not sure whether the registration distance of the C-mount lenses or of the D-mount lenses are uniform.
You will find a lot of lenses in these mounts that will work as telephotos since the crop factor is 5.6x on the Q10. But if you are looking for a 28mm equivalent, you would have to find something like a 5mm or a 1/5" focal length lens in these mounts.
The D mount lenses tend to be tiny.
