07-22-2014, 11:47 PM   #1
Focal lenght request with DA 20-40
When I change focal lenght (with body swiched off), when I switch on the body, I get the focal lenght request, as with old manual lenses. This happens not every time, every ten or so switches. I checked with two bodies (K-5 II S and K-01). Lens was serviced with another issue and before that everything was OK. This time service says everything is normal. Is that so? Has anyone experienced this?
07-23-2014, 01:10 AM   #2
clean the contact on the lens and camera, that should do the trick
07-23-2014, 02:44 AM   #3
QuoteOriginally posted by Franc Quote
Cleaning is not resolving this issue, I have cleaned everything with no result.
07-23-2014, 02:59 AM   #4
Na Horuk's Avatar
Make sure the lens is properly mounted. Its a new lens, WR, so it might be a tight fit, but it has to be mounted all the way to a little click sound.
And no, DA lenses should not ask for any info. If cleaning and stuff won't work, you should get it exchanged
Edit: Oh, also make sure your cameras have the latest firmware
07-23-2014, 05:17 AM   #5
Oldbayrunner's Avatar
Have you tried turning off the aperture in the custom menu and checking if your E-dial programming for manual is set to PLine?
07-23-2014, 05:29 AM   #6
QuoteOriginally posted by Oldbayrunner Quote
What does it mean?
07-23-2014, 06:16 AM   #7
QuoteOriginally posted by RobertCh Quote
What does it mean?
Never mind that would only matter if you were using a manual lens.
07-23-2014, 10:58 AM   #8
This would happen if the body detects the lens as not having the data contact found on AF K-mount lenses. That is why the standard advice to clean the contacts was given. If your body properly detects other AF lenses the fault is with the lens. I would reopen communication with the shop that did the repair.
body, da 20-40, focal lenght, lenght, lenght request, pentax help, request, request with da, service, time
645 lenses on K-mount focal lenght Szenario Pentax DSLR Discussion 5 03-08-2014 06:01 PM
DA 20-40 keeping me with Pentax for now loganross Pentax SLR Lens Discussion 3 01-27-2014 04:09 PM
DA 20-40 comparison with Fa 20-35? VladM Pentax SLR Lens Discussion 3 12-31-2013 09:33 PM
Focal lenght comparison with Teleconverter Scootatheschool1990 Pentax SLR Lens Discussion 7 05-10-2013 12:56 PM
wrong focal lenght with tammy 17-50 SMeK Pentax SLR Lens Discussion 5 10-20-2011 12:03 PM
All times are GMT -7. The time now is 07:11 AM. | See also: NikonForums.com, part of our network of photo forums!
