07-25-2014, 07:46 AM   #1
Outis's Avatar
Help! I can't unscrew my filter!
So, I keep a UV filter on my 15mm Limited, and I managed to screw the filter on so tight that I can't get it off on my own! Just to add insult to injury, there is a giant fingerprint on the inside of the filter. Help! What do I do!
As to how I managed to get into this mess in the first place-- I'm guessing it's from the extra torque from the screw-on lens cap. Aargh...
07-25-2014, 07:55 AM   #2
Emperor and Senpai
VoiceOfReason's Avatar
Get a piece of leather, press it across the front of the filter, hold the lens firmly, and unscrew it off. It distributes the pressure and will allow a stuck filter to come off. I've done it before.
07-25-2014, 08:10 AM   #3
...aye, and my back up tools are a simple (rubber) strap wrench, or one of these...
PENTAX K-r  Photo
07-25-2014, 08:29 AM   #4
jatrax's Avatar
Trick is do not squeeze it. The harder you squeeze the tighter it gets. Press something against the top not the sides and turn gently. If nothing else is available use your fingers on the edge but press toward the lens as you turn, just do not squeeze it.
07-25-2014, 08:38 AM   #5
Had the same issue. Bought one of these. Work great. Sensei 48-58mm Filter Wrench (Set of 2) FW-4858 B&H Photo Video
07-25-2014, 09:00 AM   #6
You can also take a couple of ice cubes and set them on the filter's frame. You want to make the filter's frame colder than the len's barrel (cold contracts, warm expands). This will loosen the filter and enable you to twist it off.
07-25-2014, 09:15 AM   #7
Ahab's Avatar
Just smash it, it doesn't belong on there anyway.
07-25-2014, 09:15 AM   #8
blackcloudbrew's Avatar
No suggestions from me but...after you remove the filter...don't put it on again. The DA15Limited needs no filters, period. There is a whole other debate on whether or not modern digital lenses need UV filters at all but I won't go into that here (I'm in the 'we don't need UV filters any more' camp).
07-25-2014, 10:10 AM   #9
forensicscientist's Avatar
Same thing happened to my 15mm. I screwed the lens cap into the filter really tight....then was able to remove the lens cap and filter at the same time. Then, it was much easier to remove the filter from the lens cap.
I tossed that filter directly in the trash, and problem solved.
07-25-2014, 10:52 AM   #10
Outis's Avatar
Thanks for all the suggestions, guys!
Yeah, yeah, I know I don't need a UV filter, but I'm a little bit accident-prone, and I would much rather put scratches in my UV filters than my expensive lenses!
07-25-2014, 11:12 AM   #11
Na Horuk's Avatar
Oh one more thing, try a temperature change. A filter can get "stuck on" due to pressure change caused by temperature change. Just making it a little warmer can make it easier to take off
Then there is also the "rubber sole of shoe" technique
07-25-2014, 11:12 AM   #12
QuoteOriginally posted by Outis Quote
Whenever this happens to me, if I pinch only one side of the filter and twist it surprisingly usually works to get the filter off. They are usually not on that tight, it is just the added pressure being applied that causes the difficulty in removing the filter.
07-25-2014, 11:28 AM   #13
SpecialK's Avatar
You want to make the filter's frame colder...
Just making it a little warmer can make it easier to take off...
One of those suggestions should help.
07-25-2014, 01:03 PM   #14
I bet you it was a Tiffen filter ?
07-25-2014, 01:38 PM   #15
ramseybuckeye's Avatar
Rubber jar openers work well.
filter, pentax help
HELP. I can't seem to get anything in focus. - Ricoh GR SCADjacket Ricoh GR 4 11-20-2013 05:43 PM
I can't believe my Luck! Boris_Akunin Pentax SLR Lens Discussion 18 07-28-2013 05:54 PM
Help, can't my K5II image preview in windows bdparker Pentax K-5 6 03-15-2013 11:31 PM
HELP I can't get my 50 off my macro teleconverter! shaolen Troubleshooting and Beginner Help 2 07-21-2012 09:20 PM
Help! I can't get the film out of my ME! heatherslightbox Pentax Film SLR Discussion 4 11-12-2007 07:36 PM
All times are GMT -7. The time now is 07:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
