Originally posted by Romeo Bravo Even changing the metering won't help and on Manual it forces the EV to stop down as far as it can.
??? On manual, you control the EV. I assume you are saying that the meter suggests minimum possible EV.
While you might gain some interesting information from a discussion here, I would suggest that you bring Pentax support into the loop. If your camera ALWAYS meters for severe underexposure, it is not something that can be solved on this forum. If it only does it in moderate to bright light (outdoors), it is still something that is beyond what can be addressed.
There are no settings or configuration options on the camera that would explain the behavior you describe.
