07-28-2014, 08:53 AM   #1
Fat Albert's Avatar
How to clean the 18-135 WR?
Hi folks,
My lens came back from the beach with a bit of sand on it. I used the rocket blaster to dislodge any visible grains...I was thinking about lightly spraying the lens with an atomizer full of distilled water. Thoughts? Anybody ever done this before?
07-28-2014, 09:08 AM   #2
I typically just put it under faucet while attached to my K5/K3 using GENTLE water flow...
07-28-2014, 09:58 AM   #3
aremmes's Avatar
QuoteOriginally posted by ruggiex Quote
Could you not do this with the rear cap on? The mount seal is on the lens, anyway.
07-28-2014, 10:08 AM   #4
VisualDarkness's Avatar
The caps are not of WR standards and don't even cover the sealing ring on my lenses.
07-28-2014, 10:30 AM - 1 Like   #5
narual's Avatar
QuoteOriginally posted by VisualDarkness Quote
These are worth investing in, if only to keep dust off.
OP/TECH USA Lens Mount Cap
07-28-2014, 02:17 PM   #6
I had some dried chlorine on my front element from a trip to a water park in Legoland two weeks ago. After blowing off any big chunks of dirt with a Rocket Blower and ever so gently dusting off the front element with a Lenspen brush, I used Purosol with a fresh cloth to clean off any "stains". Then I used the carbon end of the Lenspen to get the edges of the lens element. Be gentle. Don't apply any unnecessary force. If there is a piece of grit that you don't see then you'll only discover it after you've made a scratch in the coatings. Granted, the coatings are pretty strong but they are thin. Why stress them out any more than necessary?
I did all of this with the lens mounted to my K-30. That's a WR way of protecting the rear element.
@narual - Nice find! I think I will invest in a WR cap like that!
lens, pentax help
Ruminating over the 18-135 WR Trawlerman Pentax DSLR Discussion 18 07-22-2014 11:07 AM
Replacing the 18-135 WR? JayX2A Pentax SLR Lens Discussion 26 04-03-2013 09:02 AM
Anyone knows how to clean the oil on the aperture blade? hongzhibin1987 Pentax SLR Lens Discussion 10 10-16-2012 08:57 PM
For my soon to be acquired K-7: 18-55 & 50-200 DA WR kit set OR wait for 18-135 WR??? Loren E Troubleshooting and Beginner Help 8 10-08-2010 07:53 PM
How to clean my SMC PENTAX DA 18-55 lens from the inside? Chiefram Ask B&H Photo! 6 08-15-2010 05:05 PM
All times are GMT -7. The time now is 02:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
