Originally posted by Tom777 ... Is there one that would be best IQ, or are they all about the same. I think the 70mm may be to short but it gets a raving review??
Dedicated macro lenses are all really close in IQ, even the old ones. It is almost not worth worrying about. At least, pick all the other stuff like magnification, AF or other features first, then if you still have two lenses to compare, think about IQ. It'll probably be too close to call.
Focal length is secondary to magnification ratio for macro lenses. You are used to going from say 18mm to 55mm and seeing the details get larger in the viewfinder. But imagine you have three macro lenses that can do 1:1 maximum magnification. One is 50mm, the second is 100mm, the third is 200mm. You take a photo of the same subject with each lens at its maximum magnification. The photos all show the same size subject. Mostly the photos will be identical, with some difference in depth of field. The biggest difference is working distance. With 200mm, you are much further away from a subject than with 50mm. Your subjects suggest a good working distance compromise. Some people like to use their macro lenses for portraits or whatever, shots at normal distances. In that case, focal length works like your initial idea of focal length: 50mm has more stuff in the frame, 70mm less, 100mm even less.
