07-30-2014, 05:54 AM   #1
Hot shoe pins (contacts) voltage?
Does anyone know the hot shoe pins (contacts) voltage on a K5 so I can check it when HOT (power on).
Thanks
07-30-2014, 06:50 AM   #2
THoog's Avatar
You probably won't be able to detect anything with a voltage meter. The metal shoe is ground, the center pin is an open ground that closes to trigger the flash. The two pins to the rear receive the READY and MODE signals from the flash, so there is no voltage from the camera. The DIGITAL pin (closest to the front of the camera, upper right corner) is used for digital communication between the flash and camera. You might see something with an oscilloscope, but it isn't a continuous voltage, and there's probably nothing to see unless a flash is present.
07-30-2014, 07:06 AM   #3
Thanks for the information.... must be no contact then.
contacts, pentax help, pins, shoe, shoe pins
Hot shoe syncing crossmr Flashes, Lighting, and Studio 12 01-16-2013 04:56 PM
short circuit hot shoe contacts ok? newarts Flashes, Lighting, and Studio 3 11-18-2011 10:22 AM
SB-26 pins and K100d flash shoe Chris Stearns Flashes, Lighting, and Studio 3 04-26-2009 05:48 AM
All times are GMT -7. The time now is 10:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
