07-30-2014, 11:34 AM   #1
Is my lens sharp?
Hey guys,
last week i got my new Samyang 10mm f2.8. I did some testshots at night but i found it a bit soft. So I did this testshot on a tripod with a wired remote.
Exif: Pentax K30 (highest qulity jpg), ISO 400, 1/15sec, f8, IS off
https://www.dropbox.com/s/fp2p8axr3bxg0es/IMGP4797.jpg
(you may have to downlad it to view it in full size)
What do you think guys, is it sharp?
07-30-2014, 11:43 AM   #2
Not sure what you're looking for - but this is sharp on my monitor (1920x1200). Almost too sharp for me, sharpness doesn't make for a good photo though, only a good photo does that.
I know it was a test shot, but there's no depth to it, it's like a smartphone photo.
07-30-2014, 11:52 AM   #3
jatrax's Avatar
Also, ISO 400 is not what I would use for a test shot. Certainly usable but for tests you want everything as good as possible except what you are testing. So using ISO 400 may introduce some softness that disguises what the lens is doing.
And IMHO that is a horrible shot to use as a test. Subject is angled away from you and at all different distances, sky is blown out and lighting is bad. Not trying to critique the shot but if you want an honest test you need a subject that is aligned, has sharp detail and is properly lit. At 1/15th no way to tell if the lens is soft or the wind moved things around a bit with that subject.
07-30-2014, 12:06 PM   #4
QuoteOriginally posted by Steve.Ledger Quote
I didnt want to win a contest with that picture, i just wanted to know if it looks sharp for a 'professional eye', even at this conditions. But thank you.
07-30-2014, 12:07 PM   #5
Na Horuk's Avatar
Yes. But work on your technique.
07-30-2014, 01:13 PM   #6
VisualDarkness's Avatar
Looks pretty sharp for 10mm even out to the corners.
07-30-2014, 02:25 PM   #7
QuoteOriginally posted by Lpolzer Quote
Well, ignoring your unfriendly sarcasm towards someone who bothered to reply to your request for an opinion, and that I wasn't the only one who commented on your choice of 'test shot' - sharp doesn't equate to professional, it only means it's sharp.
The result you posted looks over sharp to me.
What are your custom picture settings in the camera?
07-30-2014, 02:44 PM   #8
Sorry, I didn't want to sound unfriendly.
So nothing too fancy - Auto noise reduction and Auto highlights.
I did this shot at night with it:
https://www.dropbox.com/s/kag3yg35liho36c/IMGP4741.jpg
To my eyes it looked blurry. Probably its due to tripod movement or high ISO. So i just wondered if its only me.
07-30-2014, 04:26 PM   #9
Yes, ISO 1600 with a lot of NR is going to make details smear.
Otherwise it looks fine to me.
07-30-2014, 04:36 PM   #10
Imageman's Avatar
Post some 100% crops please
07-30-2014, 05:13 PM   #11
QuoteOriginally posted by Imageman Quote
You can download the pictures from the link to view it in full size
---------- Post added 07-31-14 at 02:14 AM ----------
I always had the feeling that until ISO there's barely any noise.
07-30-2014, 06:13 PM   #12
jatrax's Avatar
Depends on your tolerance for noise. With k-5II I will shoot sometimes at 400 if needed but generally not happy with anything over 200. With k-3 I never shoot over 200. For what I do any noise or the slight softness caused by noise reduction is a fail.
But that is beside the point, if you are trying to do a test you need to eliminate other factors. In your test shot you have poor lighting, potential wind and high ISO any of which could cause an image to be softer than it would be in ideal conditions. If you are trying to measure how sharp that lens is in poor light with moving leaves and at high ISO, fine. But if you are trying to judge the lens itself you need to bring all other conditions as close to optimal as possible.
Shoot a well lit brick wall with the camera on a tripod and precisely aligned perpendicular to the wall, use a low ISO and a release or the timer. Then you will know if the lens is sharp.
guys, iso, pentax help, post
Whats a good sharp lens for my K20? neostyles Pentax SLR Lens Discussion 26 07-19-2013 06:17 PM
Is My DA15 Sharp? Kozlok Troubleshooting and Beginner Help 12 01-23-2013 10:18 AM
Just how sharp is sharp? (Pentax-FA 50mm 2.8) dcshooter Pentax SLR Lens Discussion 7 12-01-2011 06:04 AM
Is my A*300mm F2.8 Sharp Enough? cps_goodbuy Pentax SLR Lens Discussion 33 02-27-2010 06:29 PM
My lens is not sharp after it was cleaned professionally dycz Pentax SLR Lens Discussion 2 12-17-2009 09:24 PM
All times are GMT -7. The time now is 06:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
