07-30-2014, 01:36 PM   #1
decent quality reverse ring
What decent quality reverse ring do I need for the k3 may be a silly question
I have read about these fotodiox 52mm reversal ring and fotodioc 52mm coupling ring what is the difference and do I need both and would the work with k3
but help appreciated
Tom G
07-30-2014, 02:08 PM   #2
Reversal ring mounts the lens on the camera backwards.
Coupling ring joins two lenses together, second one reversed.
The best reversing ring I found was a legacy kiron one off ebay. But the cheap ones work OK by and large..
This web site is helpful:
Extreme Macro Photography
07-30-2014, 02:34 PM   #3
QuoteOriginally posted by marcusBMG Quote
Thanks MarcusBMG
07-30-2014, 06:05 PM   #4
OregonJim's Avatar
There is not much that can go wrong with reversing rings or couplers - just about any brand will do. I have seen one (out of dozens) that required scraping excess paint out of the threads before it would mount easily. It had no markings so I assume it was a generic Chinese part...
07-30-2014, 06:14 PM   #5
Not a Number's Avatar
I've not seen any complaints about the quality of any 3rd party reverse adapter. You can always hold out and try to find an original Pentax ring if it concerns you that much. The CAD/CAM/CNC templates for K-mounts are readily available and lens filter thread pitch are fairly standard so it doesn't take a lot to machine these. And the mount on the camera has a good amount of tolerance engineered into it (spring tensioners, etc.).
http://classic.keh.com/camera/Pentax-Manual-Focus-Close-up-and-Bellow-Access...990750250?r=FE
07-31-2014, 04:55 AM   #6
Banned
I got a couple from Adorama (Flashpoint), Don't remember what I paid, but it wasn't much, they work as expected. As previously stated, there's not much to them so nearly any brand will suffice.
08-06-2014, 05:41 PM   #7
JimJohnson's Avatar
Since this is the beginner's corner - a word to the wise, if you reverse mount a lens it must have its own manual aperture control unless you plan on always using the lens wide open.
08-06-2014, 07:40 PM   #8
Banned
QuoteOriginally posted by JimJohnson Quote
Actually, it's the opposite. Lenses w/o the ring are always stopped down all the way when not mounted to the camera in the conventional manner.
08-07-2014, 10:37 AM   #9
JimJohnson's Avatar
QuoteOriginally posted by Al_Kahollick Quote
good point - looks like my fingers got crossed ways with my brain while typing.
08-07-2014, 07:34 PM   #10
Banned
You're not alone there my friend! Happens to the best of us!
52mm, camera, pentax help, photography, quality
Reverse K-mount ring adapter users LowVoltage Pentax SLR Lens Discussion 9 08-08-2014 11:31 PM
SMC DA 18-55mm AL WR reverse ring for K-30 Markovo Pentax K-30 & K-50 10 07-26-2014 06:50 PM
50mm reverse ring squallvalentine Pentax SLR Lens Discussion 6 08-15-2012 10:07 PM
Reverse Ring Macro mikeSF Post Your Photos! 4 03-01-2009 05:07 AM
All times are GMT -7. The time now is 11:41 AM. | See also: NikonForums.com, part of our network of photo forums!
