08-08-2014, 01:09 PM   #1
devouges's Avatar
Focus limiter
Hi everyone ,
Is there a way to limit the focusing "search" on a lens.
Main reason is that when I try to capture birds in flight, I often end up searchin with autofocus searching from one end to the other....
Would be nice if I could limit the autofocus to, let's say 40 feet to infinity
Thanks
08-08-2014, 01:13 PM   #2
jatrax's Avatar
Depends on the lens. Some lenses do have limiters, 100mm macro comes to mind but it would be a lens function, nothing you can do with the camera if the lens is not already capable of it.
08-08-2014, 01:39 PM   #3
devouges's Avatar
How does the autofocus worc on screw drive ? Does it just hunt till the screw CANNOT turn anymore then just screw the other way ?
Would ibe harmful if I were to put some kind of blocking gadget on that..... somehow ?
08-08-2014, 01:41 PM   #4
That's pretty much how it works. You couldn't put any kind of blocking gadget on it without modifying the lens.
08-08-2014, 02:23 PM   #5
jatrax's Avatar
QuoteOriginally posted by devouges Quote
How does the autofocus worc on screw drive ? Does it just hunt till the screw CANNOT turn anymore then just screw the other way ? Would ibe harmful if I were to put some kind of blocking gadget on that..... somehow ?
Not exactly, it seems to work back and forth before it locks on, and if the initial back and forth finds nothing in focus then it racks the lens all the way out and back. Which is fine for most things but BIF causes problems.
Blocking the lens screwdrive from turning all the way would be considered a "bad thing". As in either stripping gears in the lens or ruining the motor in the camera. Bad idea.
08-16-2014, 06:25 AM   #6
OJGoreng's Avatar
One way around it is to use the Pentax SMC-F 1.7x autofocus adapter (AFA) in combination with a fast telefocus lens. When you set the telefocus lens to infinity, the AFA will do the focusing, but with a limited range. It works like a charm, although often the sweet spot for a bird in flight is a tad closer than the minimum focusing distance. This means you have to adjust the focus on the telephoto lens to something closer than infinity, but the closer you get, the more narrow the focusing range of the AFA gets, which means a lot of times you'll have the bird flying just outside the range. With a lot of practise you'll learn to anticipate this, but it can still be a bit cumbersome.
08-16-2014, 10:31 AM   #7
devouges's Avatar
Thanks..... I will look into that
08-16-2014, 11:11 AM   #8
audiobomber's Avatar
I reset focus to infinity or at least beyond my expected target after each series of shots. Pentax cameras almost always start racking in when looking for focus.
When your camera misses the target, rather than letting the lens rack all the way and return, use the Quick-Shift feature (for lenses that allow Q-S).
11-28-2017, 02:26 AM   #9
angerdan's Avatar
There are 16 lenses for Pentax with focus limiter.
I listed them all here:
Does any longish glass for Pentax have focus limiters? - PentaxForums.com
autofocus, camera, focus autofocus limiter, limit, pentax help, photography
Focus, Focus, Focus (or the usefulness of focus charts) GoremanX Pentax DSLR Discussion 31 12-21-2014 11:49 AM
Limiter Tjompen1968 Pentax K-3 7 04-05-2014 08:30 PM
Focus calibration - who to believe?! (hex or focus screen) heartattackandvine Troubleshooting and Beginner Help 14 12-05-2013 01:34 AM
Question about focus lock indicator on manual focus lens jostafew Pentax K-r 6 07-24-2013 10:50 AM
FA 100mm f 2.8 macro - defective focus limiter SEToien Pentax SLR Lens Discussion 5 11-03-2009 11:58 PM
All times are GMT -7. The time now is 01:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
