08-08-2014, 09:00 PM   #1
kev.pride's Avatar
K3 Firmware update 1.10
After inserting a formatted SD card (with the firmware installed into the top area outside of folders) into slot 1 and then holding the Menu button down as I turn on the K3 it simply opens up to the normal start up screen.
Followed all the steps as per the Ricoh firmware download page.
Any ideas on why this is occurring.
Kevin
08-08-2014, 09:11 PM   #2
jatrax's Avatar
Slot #1 is toward the front of the camera. I get them confused, so first thing I would check.
Second is the file needs to be the .bin file and be in the root of the card. Verify that you have the .bin, not the .exe or .zip
08-08-2014, 09:41 PM   #3
Pavel_Zhelev's Avatar
How is that possible to have folders on formated card? Please check if the card was properly formated as well as the slot number.
Hope it works.
QuoteOriginally posted by kev.pride Quote
Kevin
08-08-2014, 10:14 PM - 1 Like   #4
Kevin
Make sure you extract the download. A .BIN file should be in the root of the SD. Firmware update guide:
Pentax Firmware Update Guide - Tutorial Videos
08-08-2014, 10:43 PM   #5
kev.pride's Avatar
Thanks for responses, what appears to be happening is the downloaded exe file is not self opening as it is supposed to do.
.EXE file also says self extracting for win32 files - would this be a problem with a 64bit win on win7.
How do I get it so that the file has the 2 sub files (.bin & .txt) files.
Kevin
08-08-2014, 10:57 PM - 1 Like   #6
Otis Memorial Pentaxian
Download to your computer and double click to execute the .EXE file. This should result in extraction of a .bin and a .txt file to the same directory. Copy these into the root directory of the SD card.
08-08-2014, 11:19 PM   #7
kev.pride's Avatar
Thanks for help - this Forum is great.
Not as if this is the 1st time I have downloaded a Firmware update for the various Pentax DSLR's I have owned over the years.
Stupid Win 7 & my Antivirus kept giving warning messages - and the extracted file was in another folder all along. Once I found it and copied to SD card etc. etc it has worked fine.
Thanks again to all who helped.
Kevin
05-30-2015, 02:19 PM   #8
Same thing has happened to me ..gave up after trying for an hour..will open file first and see if that eorks
05-30-2015, 11:00 PM   #9
QuoteOriginally posted by kjbatch Quote
Instead of reviving an old thread, try the suggestions in your other thread first.
firmware, k3, k3 firmware, pentax help
K-3 Firmware Update 1.10 Released sab Pentax News and Rumors 49 09-11-2014 07:31 PM
Firmware Update K3 robrob41 Troubleshooting and Beginner Help 9 07-31-2014 11:31 AM
Issue with exposure meter in viewfinder after firmware 1.10 update SamCam Pentax K-3 & K-3 II 3 07-25-2014 02:40 PM
K3 Crazy Mirror Sickness (Mirror Flapping Lockup) on firmware 1.10 SteveUK Pentax K-3 & K-3 II 13 07-22-2014 08:08 PM
could ISO 80 be possible on the k3 with a future firmware update? Rice Pentax K-3 & K-3 II 2 05-19-2014 09:21 PM
All times are GMT -7. The time now is 04:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
