Originally posted by romansolar i will try to find more info about contact lens cleaning
I would suggest that using contact lens cleaner and a microfiber cloth is an
absolute last resort for sensor cleaning. In other words,
don't do it. I don't know what you meant in the original post when you said you had done a sensor clean, but here is the generally accepted action sequence for removing stuff from the sensor:
- Use the in-camera dust removal
- Dust still there? Do next step
- Put the camera in sensor cleaning mode and use a Rocket Blower (or similar) on the exposed sensor
- Take the camera in for professional cleaning
-- or --
use one of the commercially available sensor cleaning kits. Most of these use some sort of cleaning solution.
