08-19-2014, 09:56 PM   #1
Cee Cee's Avatar
K200 Menus won't stay on screen
Hi Guys, A friend of mine has a K200 and has an issue where the menu screens turn off after a variable amount of time, some times 1/4 or 1/2 sec, sometimes a few secs. Very frustrating , occasionally they will remain on long enough to complete your adjustments, but mostly it switches off before any adjustments or inspection of settings can be achieved. I haven't detected any other problems and batteries good, removing and refitting batteries no help. .... anybody had similar problems
cheers
CC.
08-19-2014, 11:14 PM   #2
It sounds like one of the buttons, i.e. the shutter half-press, might be stuck in the down position. Does any other erratic behavior help support this conclusion?
08-20-2014, 12:54 AM   #3
Cee Cee's Avatar
thanks Adam a fair thought, I'm not seeing any other erratic behavior at all, takes pictures fine and you can view on screen for as long as you like, other functions that come up on the screen when viewing shots like filters, histogram, info etc all ok. just menus and the fn functions ISO etc. wont stay on screen most of the time, all the buttons seem to have a definitive tactile feel to them and all seem to preform their functions. It could be some leakage across a switch or control lines on a chip or PCB, but I'd have to open it all up to check that, just thought some one may have had the same issue.
Electronics with micro controllers in them I can't count the times I've gone in search of hardware faults only to find later that its some undocumented software issue that magically disappears with a software update, or re initialization.
08-20-2014, 01:38 AM   #4
kdf9511's Avatar
QuoteOriginally posted by Cee Cee Quote
Speaking of that have you checked for the latest firmware? Maybe a reload will cure it. I know you can still download the update from Pentax's website as I did that for my K200D when I got it a few months ago.
08-20-2014, 02:34 AM   #5
Cee Cee's Avatar
QuoteOriginally posted by kdf9511 Quote
yeah that's a good point. I sort of thought that's something to try if I can't get it figured, but I maybe should do sooner than later, even reload same version might fix it, if the software/firmware is able to be changed by an update then logically its is possible to be corrupted by some event or sequence of events ( push the back button 3 times while holding down fn & info while balancing with your right leg in the air and turning clockwise)
cheers
08-20-2014, 03:13 AM   #6
Alcazar's Avatar
just a wild guess: make shure you don't have your finger on the shutter button while you use the menu... i used to do that and the fact that the screen would randomly switch off confused the hell out of me for weeks :-)
08-20-2014, 08:08 AM   #7
Cee Cee's Avatar
just updated V1.00 to V1.01 and no change to problem
---------- Post added 08-21-14 at 01:10 AM ----------
QuoteOriginally posted by Alcazar Quote
fingers are well clear of any buttons
cheers
08-20-2014, 08:25 AM   #8
kkoether's Avatar
Does it happen to have a battery grip on it? I've had that happen with the battery grip shutter button switched on. Drove me crazy at first. it's real easy to bump that button.
08-20-2014, 09:10 AM   #9
Cee Cee's Avatar
the wierdest thing - this problem only occurs with a particular lens attached (Sigma 28-90 f3.5-5.6 Macro) the problem doesn't occur with his 18-50 Sigma or 70-300 Sigma or M50 2.8 or with no lens at all attached or with any of my lense , .... what the ! ... I'll have to look into this.
---------- Post added 08-21-14 at 02:13 AM ----------
QuoteOriginally posted by kkoether Quote
he does have a grip but never uses it ( it came with the camera) seems like its a particular lens that causes the issue, hey I'll try that lens on my k30 and see what happens
well that lens seems ok on my K30
08-20-2014, 11:51 AM   #10
kdf9511's Avatar
Try cleaning and burnishing the contacts on that lens, and the body. If that's only happening with that lens it sounds like there may be something in the contacts. I don't know how many times I have spent hours tracing down a problem only to wind up cleaning every contact and connection to clear it.
08-20-2014, 06:06 PM   #11
Cee Cee's Avatar
I tried this but didn't have any effect on the problem
cheers
there must be some electrical instability in the lens which is upsetting the K200, ... so any K200 or just this one ??? I shall try it with another K200. I'll also try with my istDS.
this is an old "late film era" cheap lens and pretty ordinary at that, so not really worth wasting time with. Besides every pawn shop in Melbourne seems to have at least one of these sitting in the window for $25 or so, if he's keen to have one of these, I'll talk him into something a bit better
thanks for the help and suggestions
cheers
08-20-2014, 06:32 PM   #12
kdf9511's Avatar
Well I've exhausted my ideas unless for some reason the contacts on the mount are not lining up correctly with that body. But I wouldn't think that was the case if it works on another body.
08-20-2014, 08:22 PM   #13
Cee Cee's Avatar
well guess what, that lens caused both my istDS and K20D to misbehave in the same manor, but not the K30 ! Its headed for the bin ! ......... but yet it might be interesting to know exactly what the problem is ??
cheers
08-20-2014, 08:55 PM   #14
kdf9511's Avatar
cheers
To bad your so far away. As an electronics tech I would love to tear into one of these lenses and see what makes it tick.
08-20-2014, 09:07 PM   #15
Cee Cee's Avatar
yes ... well, as a electronics tech myself I'm about to do that, but probably not today, way to busy with my regular work
cheers
adjustments, batteries, battery, button, grip, k200, k200 menus, lens, pentax help, sigma
Optio S10 won't to stay ON Niktank Visitors' Center 4 06-05-2014 02:06 PM
Rz18 won't stay on SandraB Visitors' Center 5 02-24-2014 04:41 PM
K200 won't focus rober Troubleshooting and Beginner Help 2 12-22-2012 10:50 AM
Popup flash on PZ-70 won't stay down neal_nelson Film SLRs and Compact Film Cameras 6 09-11-2009 02:14 PM
AF540FGZ - won't stay on hot shoe ksignorini Flashes, Lighting, and Studio 8 05-23-2008 09:43 PM
All times are GMT -7. The time now is 07:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
