08-22-2014, 11:03 PM   #1
Vivitar lens won't mount to k10d
I just got my k10d from eBay today. I was extremely excited to put my Vivitar 75-205mm but I can't seem to get it to lay flat in the mount. It seems to be the result of a metal protrusion in the rear of the lens.
What gives? What is the purpose of this protrusion? Can I safely remove it?
08-22-2014, 11:21 PM   #2
Not a Number's Avatar
The shield/flange is there to protect the aperture stop-down lever. The shield can be removed or trimmed down. On some models it is just held on with screws. Other models you should remove the rear mount and cut down the flange.
There are numerous posts on how to fix this:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/240801-vivi...lange-fix.html
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/256521-thin...d-vivitar.html
https://www.pentaxforums.com/forums/120-general-technical-troubleshooting/140...k20d-crap.html
You should buy a JIS driver or two as a Philips screwdriver will likely strip out or damage the screws.
08-23-2014, 04:25 AM   #3
D1N0's Avatar
Are you sure it's a K-mount Vivitar. My 75-205 F3.8 mounts fine on the K10D
08-23-2014, 04:57 AM   #4
Tarragon's Avatar
Same concern here - I've got the same vivitar lens and been using it on my k100d with no problems. I'd be very surprised if the k10d isn't identically built for k lenses(!). Try googling some images of lens mounts to make sure you have a k mount.
08-23-2014, 08:53 AM   #5
The problem isn't confined to the K10D - it exists with any body with the power-zoom contacts include film bodies. The third party lenses with the flange problem were produced before the Kaf2 specifications were released.
08-23-2014, 02:51 PM   #6
D1N0's Avatar
Maybe this topic can help. Get a dremel (or a new 75-205 with a shorter flange). https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/186451-vivi...ing-k-5-a.html
08-23-2014, 02:59 PM   #7
I had few of those vivitars with large flange. Did use sandpaper, it was about 20 minutes work only to make flange small enough.
08-23-2014, 05:35 PM   #8
Lowell Goudge's Avatar
QuoteOriginally posted by Tarragon Quote
The interference is with the SDM contact block which did not exist on the K100
08-23-2014, 07:20 PM   #9
dms
A common problem w/ (some) Vivitar lenses. You should remove it (usually 3 screws)--only then should you cut it down, or just leave it off.
08-23-2014, 11:06 PM   #10
QuoteOriginally posted by D1N0:
Yes, I'm 100% sure. I was just shooting this with my Pentax ME Super last night.
Thanks for the post. I found my precision screwdriver set and popped it out without a problem. I'm going to file it down the next time I get a chance to work on it. Thanks for the help! I didn't know what that thing was called.
08-31-2014, 11:37 PM   #11
My fellow Pentaxians!
I am happy to announce that after going to the hardware store, buying a file, and grinding that sucker down for about half an hour, my lens now mounts to my K10D perfectly!
I overdid it, and now the flange has absolutely no shield, but it fits and that's what really matters.
camera, k10d, lens, pentax help, photography, protrusion, vivitar, vivitar lens
Vivitar 70-210mm lens won't fit K-5 plutojet Pentax SLR Lens Discussion 8 01-24-2013 06:44 PM
Vivitar 50mm f1.7 won't focus to infinity ChopperCharles Pentax SLR Lens Discussion 2 05-21-2012 12:47 PM
Pentax 18-55 lens won't mount - It used to..just stopped tfbrenizer Pentax SLR Lens Discussion 17 05-06-2012 04:57 PM
PK mount Makinon won't focus to infinity ChildOfVision Pentax SLR Lens Discussion 6 08-16-2009 04:58 PM
Weird Lens won't mount rdc Pentax SLR Lens Discussion 6 09-26-2007 05:45 PM
All times are GMT -7. The time now is 02:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
