Originally posted by geoffw I've used vivitar 283 guns and had no problems, on a K200 or a K5.
You apparently benefited from the luck of the draw. Older versions of the Vivitar 283 have been measured in the excess of 250v. Newer versions as low as 6v. I would suggest that anyone considering hot shoe mounting a vintage flash measure the voltage first.
Originally posted by Just1MoreDave All their flashes are pretty low, I think less than 10 volts. The number I've read is 30 volts.
That is my understanding as well, though I don't know that I would intentionally plumb that upper limit.
