Originally posted by GlassJunkie We use 2 different K-3 in Fla sun, no issues/ spots. Both have modified LCD protectors attached (left over from Blackberry Storms, cut to fit K-3). No spots with over-layer either. Did you use some off solvent to clean?
Personally I've not, but the camera was the last one in the shop and I fear that someone of the shop has cleaned it with something wrong...
They assure me the camera was never used and just took out from the box and I trusted them.
Originally posted by GlassJunkie Are "spots" on the glass surface, or pixels not working? I would suggest calling a CS help line at PTX. if it is not settings, seems odd...
The spots seem to on the glass, surely they aren't bad pixels... under normal light the display seems ok.
---------- Post added 08-25-14 at 01:10 PM ----------
Originally posted by GlassJunkie Is there plastic protector from the factory not removed?
If I remember well, the plastic protector was already removed when i bought it...
Tomorrow I'll go to the shop to show them the problem...
