08-27-2014, 01:52 PM   #1
Replacement part for K3
Hello all.
My K3 suffered a drop from about one metre onto concrete, it landed on the lens and the hood took the force out of the fall by shattering, however the top of the pop up flash unit has a minor abrasion.
As it is just a cosmetic plastic cover held on by four screws I would to buy another cover.
Can anyone suggest where from?
Incidentally the camera does not appear to have suffered any other damage (touch wood) a testament to the build quality and the strength of the metal body I think.
Thanks all
08-27-2014, 02:37 PM   #2
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by geordieman Quote
Wow, sounds like you were lucky to get away with that.
08-27-2014, 02:45 PM   #3
Not a Number's Avatar
You're pretty much out of luck as Ricoh changed their policy earlier this year and will no longer sell parts directly to the end customer. You may check with your Pentax dealer who may be (a big may be) able to order the part and sell it to you. One of the authorized service centers other than the main center might sell you the part but most likely they'll just quote you Ricoh's policy.
Under the new policy you'd have to send the camera in for service to get the part.
08-27-2014, 05:38 PM   #4
amoringello's Avatar
Note that Pentax has not been very quick on responding to stock requirements of the US repair center.
Ricoh recently changed repair centers from CRIS to PrecisionCamera, but backorder delays are a Pentax supply issue.
Before you send it in for repair, be sure to see if they have the item in stock.
You may be waiting three or more months to for them to get the trivial part from overseas.
If not in stock, I would see if they can order the part before you send in your camera so you can get a speedy return time.
Dunno if that is an option, but currently Pentax does not seem to care much for its customers in that regard.
08-28-2014, 08:29 AM   #5
Cheers Guys
Just put it down to a battle scar I think.
The accident was caused buy using one of those harnesses which threads onto the tripod socket, the maker claims that they will not come loose.
I doubled checked the tightness and locking collar, so I now use an addition small strap attached to the camera lug. so be very careful if you use one of these.
08-28-2014, 12:02 PM   #6
Sorry about that, similar thing happened to me, but it was because the ring on the lug unraveled when the camera got caught on a chair I was passing by.
So be careful with those, they don't necessarily hold up well and can pull off with surprising little force.
I now also use a second strap by PeakDesign as a backup. (one connected to the lugs, another to the tripod screw).
damage, k3, pentax help, popup flash, spare part
New K3 replacement this fall ? gryphongryph Pentax K-3 55 08-11-2014 12:40 AM
replacement for kit lens mtkang Pentax SLR Lens Discussion 16 12-24-2013 01:45 PM
Replacement For K20D pentaxian_tmb Pentax DSLR Discussion 10 11-07-2012 04:27 PM
Looking for ideas outside the box for Bigma replacement Eric Seavey Pentax SLR Lens Discussion 2 10-18-2012 03:23 PM
LCD screen replacement part? Eruditass Pentax DSLR Discussion 2 01-29-2012 08:08 PM
All times are GMT -7. The time now is 11:08 AM. | See also: NikonForums.com, part of our network of photo forums!
