Originally posted by FrankC Is there a software solution that would allow me to use my flatbed scanner to calibrate my inkjet printer?
Research SilverFast IT8 calibration. It's not very cheap (relatively.) What's your scanner?
I'd get the monitor calibrated and profiled first. If the Spyder software doesn't seem to be doing the job, then I'd recommend the open source
ArgyllCMS. I prefer this over the I1 software that came with my puck. You'll most likely also need the
dispcalGUI front end. Once this is installed the walkthrough is quite good.
M
