08-29-2014, 02:45 AM   #16
I leave the SR on all of the time. If the shutter speed is really fast, it doesn't need SR, but it doesn't seem to make a difference in the quality of the photos. If I am on a tripod, I usually use mirror lock up or 2 second timer and those settings automatically turn off the SR. This is the big place you don't want to use SR, because if you leave it on, the camera tries to compensate for movements that aren't there and can actually introduce shake. Or so I have been told.
08-29-2014, 05:36 AM   #17
QuoteOriginally posted by kchamber4 Quote
Does anyone know if using RF on the K3 will automatically turn off Shake Reduction as Johnyates indicated above on his K5?
If "RF" means the infrared remote control, then yes, this setting disables Shake Reduction on the K-3 (page 47 of your manual, the section on "Setting the Drive Mode").
08-29-2014, 07:12 PM   #18
Steve, actually the K100 I believe was the first. At the time pentax released the K100 and the K110 where the only difference was SR. The K10 came a little later.
You are right! I forgot that the K100D was available before the K10D by a couple of months. I bought my K10D sight unseen after having handled a K100D.
control, pentax help, shake, shutter, time
Disable Shake Reduction when using tripod? *Rich Photographic Technique 9 05-26-2013 02:54 AM
Using my shoulder to reduce camera shake? R.W.G. Photographic Technique 5 04-10-2013 03:09 AM
AF while using remote control johnny6.6 Troubleshooting and Beginner Help 9 03-08-2013 04:00 AM
sensor shake in live view using manual lens jaeaetee Troubleshooting and Beginner Help 10 02-20-2013 08:12 AM
Using Shake reduction w/Teleconverter sportster64 Pentax DSLR Discussion 8 10-09-2007 09:08 AM
All times are GMT -7. The time now is 04:35 AM. | See also: NikonForums.com, part of our network of photo forums!
