08-29-2014, 01:12 PM   #1
K30 will not turn on
This has happened to me twice, and most recent today. I was using my K30 turned it off and took the card out to download pictures. Put the card in to format and the camera would not turn on. I took the battery out and put it back in and all works fine. This happened twice in the past several months. Both times the camera was off and I had taken the memory card out to download shots. All my batteries are clean and in good condition.
08-29-2014, 01:25 PM   #2
jimr-pdx's Avatar
My K-5 won't power up without a chip, so you might pull it out and re-insert.
I've done this to myself several times, leaving the chip in the computer read-slot
08-29-2014, 03:30 PM   #3
virusn3t's Avatar
This happen to me every time i took the card and turn off the camera without closing the "flap" where the card goes, if i try to reinsert the SDcard it just dont turn on again until i remove the battery.
Sorry for my bad english
08-29-2014, 04:01 PM   #4
6BQ5's Avatar
Sometimes I wonder if this happens because the camera thinks one of the access doors is open. The indication cannot be reset unless the camera is power cycled. This happens to me randomly and has no relationship to the SD card. My K-30 may have the card installed and all doors closed and it locks up. I open and close the doors to no avail. Finally, I pull the battery and reinsert it. Then all is well.
08-29-2014, 04:16 PM   #5
DeepThrob's Avatar
QuoteOriginally posted by 6BQ5 Quote
When my k30 wouldn't (seemingly) turn on. I discovered that the camera still worked. just no lcd. Pulling the battery overnight did nothing. Then I noticed that the camera would start even if the door was opened and that's not right. I found the little plastic switch and worked it in and out a few times. It's been fine since. Goofy little crap switch.
camera, card, download, k30, pentax help
k30 Firmware Problem / Now camera won't turn on aniro Troubleshooting and Beginner Help 7 11-27-2013 02:11 AM
K30 Really Slow to Turn On CanadaGuy Pentax K-30 & K-50 6 04-29-2013 11:51 AM
K-5 will not turn on - Pentax Support advice carrrlangas Troubleshooting and Beginner Help 2 01-10-2013 11:02 AM
Sr will not turn off Willowzxx Troubleshooting and Beginner Help 2 07-07-2011 07:14 AM
K-m DSLR Will Not Turn On Robbie28 Troubleshooting and Beginner Help 7 02-26-2011 09:22 AM
All times are GMT -7. The time now is 01:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
