09-04-2014, 09:33 AM   #1
Super Takumar's Avatar
Can I use my K1000 as a light meter?
I just recently purchased a Bronica ETRS, and it has a non metered prism. With that said will, my Pentax K1000 work sufficiently as a stand alone meter for a medium format camera?
09-04-2014, 09:49 AM   #2
Otis Memorial Pentaxian
Yes, you can use your K1000 to meter a scene. The area metered will be the area of the viewfinder image with a slight weighting to the center. Better would be a hand-held meter allowing both incident and reflected readings and even better would be the meter prism or a spot meter.
09-04-2014, 09:49 AM   #3
sure, your iphone will work equally as well with a 1$ app.... remember to put the cap back on the k1000 after each meter or the battery will drain!
09-04-2014, 10:19 AM   #4
Very interesting question.
I can not see any reason why not, except that it will be a very roundabout way. I think the K1000 has a centre weighted meter and you will have to transfer the shutter speed and f stop settings that you get with the appropriate ISO set to your Bronica.
The format should make a diference
09-04-2014, 10:41 AM   #5
Dark Underlord
AquaDome's Avatar
I have used my K-50 to do it. No reason you couldn't use a K1000 to do the same. You might find a hand-held meter to be more versatile and easier to store in the bag with the Bronica.
09-04-2014, 11:01 AM   #6
Thank you.
I really don't want to spend money on a meter, or a metered prism for the Bronica.
It should fine for my application, mostly still life and some portrait work in the future.
09-04-2014, 11:12 AM   #7
aremmes's Avatar
QuoteOriginally posted by Jamey777 Quote
I use the Pocket Light Meter app on my iPhone. It's free if you don't mind ads (still full-featured, though), otherwise it's $1.99. It's intended to use the Luxi clip-on to use the front-facing camera for incident light metering, but I found that the translucent body mount cap from my K-50 works for the same purpose.
09-04-2014, 11:23 AM   #8
FWIW, I have had poor luck with the light meter apps for Android (can't speak for iPhone). The Android apps work by extracting the EV from the exif on a test exposure*. Unfortunately that often does not translate well to other cameras. I have found the phone metering to vary several stops from my hand-held and SLR meters. As always, YMMV.
* Or something like that...
09-04-2014, 12:30 PM   #9
johnyates's Avatar
Put a long lens on it and you've got a spot meter.
camera, k1000, pentax help, photography
Pentax 67: can I use a K-30 as a light meter? How? Guizo Pentax Film SLR Discussion 7 12-30-2013 01:12 PM
Got a K1000, what lens can I use? MegaPower Pentax Film SLR Discussion 11 03-08-2011 07:46 AM
K-x as a light meter Eagle_Friends Pentax DSLR Discussion 7 10-15-2010 05:32 AM
Can I use DPI as a print-protection method? BBear Digital Processing, Software, and Printing 75 04-22-2009 08:57 PM
some of my best... use of light... hope K10 can do as well :) slip Post Your Photos! 13 01-24-2007 07:28 PM
All times are GMT -7. The time now is 05:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
