09-06-2014, 08:33 AM   #1
double shots when sutter is pushed
My Pentax Kx has started taking two quick shots when I push the shutter. it has not done that before ( 2 Yrs ) Also, I now have a clunking noise when the camera is turned on
09-06-2014, 08:40 AM - 1 Like   #2
jatrax's Avatar
Clunking noise is most likely the dust removal system. Do you have it set to run at startup? It's best if you do.
Double actuations are often caused by the shutter button sticking just a bit. The k-x button has a reputation for that. Try this: with the camera OFF, push the shutter button firmly all the way down, and repeat about 50 times or so. I know that sounds weird but it has worked for a number of people, including me. If that does not work then you will need to do a better cleaning which might be best done at a camera shop. Some on this forum have reported using electronic cleaner to good success to free up the button, but I've no experience with that.
09-06-2014, 08:49 AM   #3
paulh's Avatar
+1 to jatrax's suggestion. I have an *istD with a similar problem, and "exercising" the shutter button seem to work
09-06-2014, 09:22 AM   #4
zekewhipper's Avatar
Do you have some bracketing function turned on?
09-06-2014, 10:51 AM   #5
Is continuous shooting turned on?
09-06-2014, 11:08 AM   #6
You're most likely in continuous mode. Check your drive mode setting (up button).
09-06-2014, 01:16 PM   #7
micromacro's Avatar
I do have double click problem in single mode with K200 sometimes. It's a second hand camera, so I got that problem since the beginning of using.
jatrax, interesting solution, thanks.
09-06-2014, 04:03 PM   #8
kiwi_jono's Avatar
Yep not that uncommon. My K-x does that sometimes (and bracketing / continues modes are off). On mine its seems to be "contact bounce" on the shutter button (I have an electronics background) - possibly caused by contacts only just closing at the bottom of the buttons travel. I will have to try Jatrax idea too!
09-07-2014, 12:00 PM   #9
QuoteOriginally posted by lowndes2 Quote
Don't know how to reply to all the answers but the exercising the shutter button has fixed my problem - thanks to all who answered - also now have the dust removal system to run at start up
09-07-2014, 12:29 PM   #10
jatrax's Avatar
Glad you got it working!
09-07-2014, 02:58 PM   #11
PEG Moderator
Kerrowdown's Avatar
Well there you go, they say you learn something new each day, well this is mine for today.
pentax help, shots
When to use: Exposure locked when focus is locked? Concerts? rzarector Troubleshooting and Beginner Help 7 04-09-2014 09:35 AM
double exposure shots jkjack Pentax K-30 & K-50 11 07-26-2013 06:06 PM
K01 - main switch turn off camera in on position when pushed clockwise Foma2 Pentax K-01 5 01-23-2013 03:06 AM
K5 makes double shots cees Pentax K-5 31 01-08-2013 07:29 AM
When comparing bodies, lenses, brands: why not single- or double-blind tests? thirdofthree Pentax DSLR Discussion 8 09-02-2009 11:55 AM
All times are GMT -7. The time now is 06:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
