Originally posted by jcshellyg That's what I was afraid of jatrax. I had seen some tips on how to do it on other Pentax models so was hoping this one could be done as well.
If it comes down to it you can remove and replace the LCD panel. If in your head right now you don't know what size screw driver to use, don't do it. If you do and you are a do it yourself/try type of person. Here is a link to many Pentax models. Pentax keeps the same basic design through the years; different but same concept. I don't know if you can just unplug your LCD. Do you know how to work with what looks like just plug in pull out connections? Because many don't work that way?
If yes here are a bunch of manuals. Look for the password in the files.
Downloads
Now the part? Well your lucky. The part is easy to get and very cheap. Ebay USA $35 from China. LCD screens are fairly cheap.
When you look at the screen at eBay please note the connector it uses.
