09-09-2014, 11:42 AM   #1
photographing lightning at daytime. Is it Possible
I am trying to photograph lightning during day time hours. Is this a something that can be done with reasonable expectations.
09-09-2014, 12:10 PM   #2
It is possible with small stops and slow ASA settings. I try to time the bolts but you will miss quite a few doing this. With film it was wasteful but shooting digital there are no worries about wasting frames. Sometimes putting a polarizer in front helps to give you a bit longer exposure.
09-09-2014, 12:27 PM   #3
Stone G.'s Avatar
I am pretty certain that you will need a Neutral Density filter under most circumstances. See for example here:
6 Tips on Photographing Lightning During the Day - Digital Photography School
09-09-2014, 03:50 PM   #4
FrankC's Avatar
The surefire way is to use a lightning trigger - [lightning trigger] | B&H Photo Video
09-09-2014, 03:51 PM   #5
Ex Finn.'s Avatar
Google "lightning trigger".
09-09-2014, 04:19 PM   #6
Tan68's Avatar
Good hood is even more important with the longer exposures using ND
...just in case that is news :^)
If you try the ND idea, I would look at 10-stop or so...
09-09-2014, 04:43 PM   #7
Ex Finn.'s Avatar
For a ND to work, the strike would have to be very close... Scary close IMO.
There are some images out there taken with a trigger in daylight. Google for them...
09-09-2014, 05:06 PM   #8
Tan68's Avatar
OK...
Because at night you would have a long exposure
During day with the ND filter, you would have a long exposure
Sounds like the same so what is the problem...
At night, the lightening is massively brighter than ambient and your exposure is based on ambient
At day, with the ND, your exposure is based on ND+ambient...
Yet the lightning is no longer massively brighter than ambient.. [so it wouldn't show as well as at night]
Right ?
I had to think about that some
ND seemed to have been a good suggestion...
QuoteOriginally posted by Ex Finn. Quote
09-09-2014, 05:15 PM   #9
Ex Finn.'s Avatar
QuoteOriginally posted by Tan68 Quote
Yes indeed. Depends on the desired intensity.
lightning, pentax help
Is it possible to take apart Takumar 28/2.0? kitestring Pentax SLR Lens Discussion 11 08-28-2013 02:42 PM
Is it possible to use manual flash in TAv mode? ismaelg Pentax DSLR Discussion 3 07-09-2013 11:52 AM
Tips for Photographing Lightning? snake Photographic Technique 13 07-26-2012 05:30 PM
change file naming prefix: is it possible at all? Gian Pentax DSLR Discussion 3 10-22-2009 08:09 PM
What single lens can do it all? is it possible? bolek Pentax DSLR Discussion 18 10-26-2007 07:33 AM
All times are GMT -7. The time now is 04:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
