Originally posted by James78 Thanks Steve for looking into this. I just put multiple lenses and run tests again. All photos taken with 1/100 F2.5 ISO100, except the 85mm all are 50mm. For those with manual focus I tried both focusing from near-to-far and then far-to-near and in both cases I shot right at the edge of focus confirmation to get a sense of both boundaries.
Here's list of original files as below:
Pentax-DA 50mm - autofocus
Pentax-FA 50mm - autofocus
Pentax-M 50mm - manual focus near-to-far
Pentax-M 50mm - manual focus far-to-near
Rokinon 85mm - manual focus near-to-far
Rokinon 85mm - manual focus far-to-near
Thanks! The FA 50 and DA 50 shots are reversed. The one labeled FA 50mm (taken with DA 50/1.8) is better than the others, but still does not look right. The art work and frame are not sharp. DOF at that distance and f/2.5 is a full meter with the near limit being 45 cm in front of the point of focus, yet the threads on the umbrella have about the same sharpness as the pressed wood border on the artwork. It appears the point of focus is at about the plane of the metal tip of the umbrella.
The shot with the FA 50/1.4 at f/2.5 is definitely focused at or near the tip of the umbrella, but the frame is softer over all, possibly due to LaCA visible throughout much of the frame or camera motion. The Rokinon 85/1.4 at f/2.5 shows similar front focus and some evidence (I think) of camera motion. Is it safe to assume these shots are hand-held?
The M 50 shot is simply nasty with no apparent point of focus within the field.
It is likely that you have got a significant calibration or other issue with your AF system that is not limited to manual focus. I suggest we step back a little and do a bit of basic testing. Here is the setup:
- Camera on tripod
- Drive mode on 2s delay. This disables shake reduction should you want to take a test exposure.
- High contrast focus target taped to a wall. I use a lens test target* printed on glossy photo paper.
- Focal plane of camera 20x the lens focal length from the target with care taken to make sure that the focal plane is parallel to the target
- Moderately bright natural light. The AF system has issues with some types of artificial lighting.
What we have done is to make it easy for the camera to attain focus on an unambiguous target without concern for target topography or AF point size or target contrast. Now to do a quick evaluation:
- Mount your DA 50/1.8 to the camera. Place a piece of tape on the focus ring to allow you to mark the focus point.
- Switch to manual focus and rack the focus to infinity
- Slowly move the focus ring until the AF system beeps and the green hexagon displays
- As soon as focus is attained remove your fingers from the lens and place a pencil mark on the tape immediately opposite the "1" in "DA 1:1.8 50mm" on the lens body.
- Switch to magnified live view
- Attempt to obtain a sharper image using live view and write down whether you turned the focus ring to the right (towards infinity) or to the left to make the correction. It makes no difference how far.
- Repeat several more times (at least 5 total) focusing from infinity to 1 meter, noting the direction to correct each time
- Do the same number of attempts working from minimum focus distance to one meter, writing down each time the direction to correct.
The tally should clearly indicate whether you have detectible front or back focus with that lens.
The reason why I suggested the DA 50/1.8 is that it is a relatively new, sharp, and high contrast lens. We want to give the AF system every advantage. You can repeat the test now at a longer distance (1.7 meters) with your Rokinon 85/1.4. With any luck, you will see a similar pattern as with the DA 50.
In regards to your FA 50 and M 50 lenses. I would suggest that you do a careful inspection of both lenses in dim light using a small flashlight (torch) shining obliquely through both the front and back of the lens while observing for fungus or gross damage to the lens elements. Your example image for both those lenses did not look right**, regardless of focus and it would be good to make sure the optics appear clear and clean inside and out. There may be a physical reason.
Camera Lens Testing- Sharpness, Chromatic Aberration and Distortion - Bob Atkins Photography
** My M 50/1.7 is marginally sharper than my DA 50/1.8. I would expect yours would have similar performance when compared side-by-side.
