09-11-2014, 11:51 PM   #1
screwdriver222's Avatar
K3 possible firmware glich
firmware version 1.11.
Direction pad (4 way controller) does not work when auto focus mode set to A9 or Sel 1,2,3,4.
Can someone try this and confirm that it should work.
Cheers
Jeff
---------- Post added 09-12-14 at 08:08 AM ----------
Ahhh.... just realised the D pad is used to move and select the auto focus area. But how can I choose the drive mode, white balance etc.
Cheers
Jeff
09-12-2014, 12:11 AM - 1 Like   #2
kpl
You can use the button for SD card slot selection (bottom right corner of the direction pad) to toggle between moving the AF area and drive mode, WB etc.
Cheers,
kpl
09-12-2014, 12:17 AM   #3
Hi Jeff,
It works ok for me - what lens are you using?
ah - just read klp's post
09-12-2014, 12:52 AM   #4
Thanks. It works a treat. I'm on holiday and the other day a flock of geese flew close overhead and I couldn't get into continuous shooting mode.
Cheers and thanks for the quick response
Jeff
auto, cheers, firmware, focus, jeff, k3 possible firmware, mode, pad, pentax help
Firmware Update K3 robrob41 Troubleshooting and Beginner Help 9 07-31-2014 11:31 AM
could ISO 80 be possible on the k3 with a future firmware update? Rice Pentax K-3 2 05-19-2014 09:21 PM
K5 IIs firmware v1.07 possible bugs RogerD_AZ Troubleshooting and Beginner Help 23 04-24-2014 01:49 PM
Possible to install older version of firmware? Kurt Euler Pentax K-5 2 04-05-2013 09:51 AM
Possible new firmware coming ? westmill Pentax K-5 29 10-20-2012 05:44 AM
All times are GMT -7. The time now is 06:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
