09-15-2014, 12:19 PM   #1
FA77MM focusing-ring stuck, can not focus.
Recently, I noticed my FA77mm has a focusing problem.
For some reason, the focusing ring seems to be tracked in some position (the telescope end).
When the cameras (both K01/K5) were set to "autofocus", then I half-pressed the shooting button, I could only hear the noise of the motor, but the viewfinder didn't change.
When I set the cameras to "manual focusing", I still couldn't rotate the focusing ring.
The stuck-focusing-ring problem existed when the lens was removed from the cameras.
This FA77 is a Vietnam assembled version.
Anyone encounter this kind of focusing problem before?
Any suggestion? Thanks a lot!
---------- Post added 09-15-14 at 03:23 PM ----------
My cameras are fine with other lenses, such as FA31MM or 16-45/F4.0
09-15-2014, 03:32 PM   #2
It appears that you have done all the right steps to isolate the problem. The focus mechanism on your lens is mechanically jammed or broken. I am unaware of any known tendency of the FA 77/1.8 to this sort of problem nor can I remember any report on this site of anything similar. I would not want to speculate regarding potential causes. It is enough to say that they span the full gamut of manufacturing defect, abuse, and normal wear. I would suggest a professional repair.
09-16-2014, 12:11 PM   #3
Thanks a lot, Steve.
I checked the price list in Precision Camera.
The price varies from $78.50 to $228.50, plus the part fee.
I'm not sure how serious the focusing ring problem is, whether It's possible to fix it personally.
Personally, I have a handy-hand, but I never fix a lens before.
If it's not that serious and could be fixed in a somehow not too complicated way, then I want to try it myself.
Otherwise a professional repair is needed.
That's why I'm seeking advices.
09-16-2014, 08:36 PM   #4
QuoteOriginally posted by dawaylong Quote
It requires special tools. I can recommend Micro Tools as a source for the JIS screwdrivers and specialized spanners and lubricants.
Micro-Tools, Camera & Watch Repair Tools - Home
If parts are required, they may be difficult to get. Ricoh no longer sells parts to individuals. You might want to contact Eric Hendrickson, an independent Pentax-trained repair technician in Tennessee. He is competent and is fair in his pricing and is an honest professional.
Eric Hendrickson: pentaxs.com
09-16-2014, 08:46 PM   #5
Deimos's Avatar
I had the same problem with my 77 MIJ. The focus ring started to feel a bit gritty then not long after got stuck, then it could be moved a bit but seemed to no longer correspond to correct focus. I sent it to Eric, he wants $85 to repair the ring, clean the optics, refocus the lens and ship it back to Canada.
09-17-2014, 08:40 AM   #6
Thanks a lot for the info.
Actually I have watch tool set.
But I will contact him, because I don't know how serious the problem is.
---------- Post added 09-17-14 at 11:42 AM ----------
QuoteOriginally posted by Deimos Quote
This information is really helpful!
Thanks, Deimos!
Do you still have his contact?
I would like to contact him!
Best,
Dan
09-17-2014, 09:43 AM   #7
mikeSF's Avatar
that sounds like the behavior mine was showing moments before the whole front of the lens fell off on the ground due to three loose screws. I recommend getting it in for repair.
09-17-2014, 05:55 PM   #8
Beware the cross-head screws are JIS and require a compatible screwdriver.
---------- Post added 09-17-14 at 05:56 PM ----------
Same Eric that I gave you the link to.
09-17-2014, 08:38 PM   #9
Deimos's Avatar
Thanks, Deimos!
Best,
Dan
You can contact him here: Home
09-18-2014, 08:40 AM   #10
Gotcha, thanks a lot.
---------- Post added 09-18-14 at 11:41 AM ----------
Got it, thanks
bit, cameras, contact, eric, fa77, fa77mm, fa77mm focusing-ring, focus, focusing problems, focusing ring, hendrickson, pentax help, post, repair, steve, thanks, tools
DA35/2.4 with a stuck focus ring...any ideas? fun size nick Pentax SLR Lens Discussion 5 02-05-2013 04:59 AM
Stuck focus ring (Pentax-A 50mm F/1.7 Barron Pentax SLR Lens Discussion 4 07-18-2012 04:18 PM
Porst 55 f1.2 with stuck focus ring! Clavius Pentax SLR Lens Discussion 6 04-30-2012 03:55 AM
DA 40 Focus ring stuck gus007 Pentax SLR Lens Discussion 9 12-13-2010 01:13 PM
Repair in Toronto/Canada/US for stuck focus ring DroolingCrow Pentax SLR Lens Discussion 6 08-21-2010 02:05 PM
All times are GMT -7. The time now is 05:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
