09-21-2014, 11:00 AM   #1
K5 colors in submodes (Av,Tv...)
Hi,
I have a big problem with colors on my K5 photos taken in a submode like Av, Tv... in automatic mode, the pictures are looking fine, but I normally don't use that very often.
I also own 2 K200d and I have no problems there.
Factory reset has been made, but the problem is still there. I hope somebody here can help me, cause on next saturday I will be on a wescoast trip and I would love to take a lot of good pics.
Automatic-mode (green) (sorry for my messy office )
http://www.loonytom.de/IMGP5086.JPG
Same picture in Av-mode
http://www.loonytom.de/IMGP5084.JPG
Any ideas?
09-21-2014, 11:16 AM   #2
White balance in green mode is Auto, you don't have it in auto in the other modes.
When you are inside it is best to use the custom white balance setup, just use apiece of white paper to set it.
09-21-2014, 11:46 AM   #3
jatrax's Avatar
According to the EXIF you have your white balance in manual. Either set it to automatic (AWB) or you have to set it manually for whatever light you are in. K-5 AWB is not bad, best to leave it there unless you are going to re-set it for each lighting situation. As noted above in 'green' mode the camera goes to AWB automatically.
09-21-2014, 11:46 AM   #4
Tan68's Avatar
Or, if he doesn't want to set custom WB, he could just be sure to turn it to 'auto' when in Av or whatever and that should make the colors be about the same as Auto/Program[meant green] with auto WB ?
colors, colors in submodes, k5, k5 colors, pentax help
Prevent ISO Shift in Av or Tv Mode nanhi Pentax K-5 12 12-01-2013 09:35 AM
K5 Taking photos in AV PentaxBirdLady Troubleshooting and Beginner Help 8 09-27-2013 01:24 PM
K-5 Underexposure in Tv and Av Robinvic Troubleshooting and Beginner Help 11 11-27-2012 06:38 PM
Is Av Shift and/or Tv Shift in TAv Mode possible. robert_s Pentax K-5 3 09-30-2011 09:03 AM
Metering in Av or Tv mode sany Troubleshooting and Beginner Help 23 04-27-2011 09:31 PM
All times are GMT -7. The time now is 06:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
