Originally posted by Digitalis Could you post a picture of the small figurine?
A thought has occurred to me: do you have the internal camera flash exposure compensation set to zero?
For the last round of tests desrcibed above: 1) the flash was set at "auto" with no exposure compensation; 2) the +/- metering compensation on both cameras was set at zero; 3) the flash output adjustment accessed via the camera's four-way controller was set at zero. Matrix metering was used (during the first round of testing I switched to spot metering twice but it made no visible difference to the exposure obtained immediately before using matrix). I dumped all the files from the two cards used, so I'd have to reassemble the set-up and repeat the test to post any images. I'm loath to do that because the flash has been packed away for a second time to be returned for a refund, and I'd rather not take it out again.
AGAIN, I conclude that PTTL WILL NOT FUNCTION with any manual SMCA lens. If anyone has obtained correct PTTL exposure using an AF160 and an SMCA or SMCM lens, please post your experience as it might indicate that this particular flash unit was defective, but I doubt that, as it did give correct exposure with a DA 35mm f2.8 macro, provided the subject were not too close (the flash instructions list a minimum distance), and also gave correct exposure with test shots taken with DA 70mm f2.4 @ 4 feet and both f8 and f16. Also, the flash gave the same unsatisfactory exposures using SMCA lenses on two different Pentax bodies, K5 & K3. I think I've given the flash every chance to work properly with a manual focus macro lens, but it does not. As noted, if manual flash is necessary, I'd rather use my old Sunpak ring flash because it has a wider selection of manual outputs. (1/2; 1/4; 1/8; 1/16), the flash head is smaller and it's a full ring, not two half-rings.
