Originally posted by Storm Chaser I shoot 99.9% outdoors, in mail yesterday new toys Tamron 28-70 f2.8 and Cactus RF-60, V6.
Was told that I will be taking photos at a pre shoot preforming arts play. (The guy with no time with flash etc.....funny)
4- Shoot manual with set up?
5- The stage will have lights and house lights will be on. Type of lights anyones guess?
Any help would be grateful! Thank you
Not too sure what a pre shoot is but in theater, with theater lighting, unless you have a lot of time and understand off camera lighting, I recommend using the theater lighting.
Forget the flash (congratulations on new gear), especially mounted on the camera. Use the stage light which will probably be hot lights, so tungsten balance.
Shoot manual and shoot RAW, DNG. If they are static poses, 1/125th or so at f4 and ISO 1600 or 3200 should do. Move the actors to use the stage light. Work with the lighting person.
Stages are typically EV 7 or 8 at ISO 100 so you can adjust with your histogram up or down stop, easy to figsure with Sunny 16 rule. Don't be afraid to underexpose when shooting raw, lots of DR in K5 sensor. I'm betting the 70-200 will be too long unless its for head shots. Here's an example done during a rehearsal for Giselle. K-5 & 12-24. 15MM, f4, 1/125th, ISO 1600. The flare was on purpose. I akse the lighting person for a down spot and liked the way it looked. Work with the director to pose.
