09-27-2014, 04:49 AM   #1
gmans's Avatar
Relieved K50mm 1.1,2 ok, but K.01 problem
Was thinking that I killed the 1.2 50mm could not get a sharp image out of it, it was in lens bag and was slight drop of 400mm ( butter fingers). was ready to send it off for repairs. Discovered that using it on K01 and the aperutre step/kick down mechanism is not working on any of my manual lens (every manual lens works on K3). Went through the menu of K01 and could not see any setting that was awry.
Is there any thing I am missing that could lead to the kick down not working on the K01?
Any feedback would be appreciated.
09-27-2014, 05:04 AM   #2
Digitalis's Avatar
you can only use K and M series lenses in Manual control modes - SV,TaV,P,S,A, modes won't stop a M or K series lens down. Only M, B, and X modes allow for that.
09-27-2014, 05:12 AM   #3
gmans's Avatar
Cheers mate, will go through the settings again and give it another go, I thought it was in M manual mode, but maybe the dial was not set. Thanks.
09-27-2014, 05:18 AM   #4
manntax's Avatar
QuoteOriginally posted by gmans Quote
Make sure you have ISO set to a fixed value - not AUTO , and of course in 'M' mode with green button, this should solve your problem. Setting ISO to AUTO in M mode with K or M lenses will effectively mean that your camera shoots wide open with AUTO ISO and auto shutter speed.
09-27-2014, 05:53 AM   #5
gmans's Avatar
QuoteOriginally posted by manntax Quote
Thanks, shall give that a go, tomorrow. Good night from over here.
09-28-2014, 12:28 AM   #6
gmans's Avatar
Thanks for you help, here's a glass of red for you both @ 1.1.2.
PENTAX K-01  Photo
09-28-2014, 12:35 AM   #7
manntax's Avatar
Very nice, congratulation and good luck in using this fabulous lens !
09-28-2014, 10:16 AM   #8
gmans's Avatar
Cheers, the lens is tripod only at f1.2, that shot was the first time I've nailed focus. All the other times have been trying hand held and the slightest movement puts you out of focus.
k01, lens, pentax help
A50/1.2 cheap! But there is a problem... bhairavp Pentax SLR Lens Discussion 13 04-06-2013 07:17 AM
what is more precious to get 1st ? summicron 50mm or k50mm/1.2 ? photoshoper Pentax SLR Lens Discussion 4 12-30-2012 10:50 PM
Flash problem on power 1/1, 1/2 gabro822 Flashes, Lighting, and Studio 4 12-09-2012 09:22 PM
43mmltd or K50mm/1.2 ?? axl Pentax SLR Lens Discussion 44 08-04-2010 11:48 PM
K50mm/1.2 beyond repair? SteveM Pentax SLR Lens Discussion 27 01-06-2010 02:27 PM
All times are GMT -7. The time now is 11:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
