Originally posted by Oldbayrunner Dump it....
From Marcus link....
"A first generation manual P-KM mount, easily distinguished from the later mount by the lack of a black flange with f numbers on, and only one tab. This is probably best avoided except to use specifically with certain early adaptall lenses" - See more at:
Information page on Tamron adaptall, adaptall-2 system and lenses Yes you're right that is the 1st gen mount. But I should actually test the functioning of the darn thing since I have one and make a clearly definitive statement on my web page.
In any event the OP CAN use the mount, operating in Av, using the A-M switch to stop down manually. Which is what I tend to do with these AD-1 lenses in any case it's one of their advantages.
Try it out Jessamyn, set mode dial on AV, focus switch on MF, make sure you've set "use aperture ring" in the settings etc. Put the A-M switch on A - aperture will be wide open and will stay wide open when you click the aperture ring round to eg f5.6, f8 (whatever you want). Focus and frame. Then just before pressing the shutter, flick the A-M switch to M. You will see the viewfinder go dim because the iris closes. Press the shutter.
Addendum: you will almost certainly need to use the exposure compensation function (the wee button with +/- on it). Typically I am compensating up to around +1eV to get the exposure right.
