10-07-2014, 02:25 AM   #1
spotmatic 2 metering
Hi, have spotmatic and am wondering how the metering works?
Have read an online manual for it and know i have to engage the SW button to meter. The manual says that if needle is close to + it will be over exposed.
I have iso125 film loaded it and have set the dial to be first mark past the 100 iso mark.
I point it at a wall with setting of 1/15 f 8, with this settng the needle rest in the middle.
The manual states that if the needle is close to the + it will overexpose, thing is if i increase the shutter to 1/60 the needle goes right up to + mark, if use f22 it does the same, if use f2.8 it goes to - mark?
This does not seem to correspond with what manual states, it seems to be the opposite?
So what is the correct method to judge under / over exposure?
thanks
10-07-2014, 02:54 AM   #2
This is just a guess, but did you insert the battery upside-down? Sounds like the needle is going up when it's supposed to go down.
10-08-2014, 02:08 AM   #3
that did the trick, thanks
10-09-2014, 05:16 PM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by bubblecatcher Quote
The brackets that frame the needle in the viewfinder indicate one stop over/under.
10-11-2014, 04:14 PM   #5
ebooks4pentax's Avatar
I wish they would reissue the Spotmatric with a digital engine.
camera, mark, needle, pentax help, photography, spotmatic, troubleshooting
Spotmatic F - Metering Seby123 Troubleshooting and Beginner Help 13 06-08-2017 07:23 AM
Exposure metering quirks of a Spotmatic 6BQ5 Film SLRs and Compact Film Cameras 8 02-05-2014 03:20 PM
Spotmatic F metering - old topic, new twist Seerixpix Film SLRs and Compact Film Cameras 11 06-22-2013 09:18 AM
Spotmatic F Metering Issue Periodista Film SLRs and Compact Film Cameras 4 09-22-2010 04:18 PM
Noob spotmatic metering question SPII Film SLRs and Compact Film Cameras 7 04-30-2010 01:25 AM
All times are GMT -7. The time now is 12:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
