10-07-2014, 11:39 AM   #1
Metering Method
I will be shooting outdoor portraits of a single subject in a park. I will have off camera flash and reflector kit and I'am wondering what metering mode would be the best choice? Thank You (Sorry have K5lls)
10-07-2014, 11:48 AM   #2
Bcrary3's Avatar
Typically centre weighed metreing is the best IMHO
10-07-2014, 12:20 PM   #3
QuoteOriginally posted by Bcrary3 Quote
Thanks, TTL works fine in Center weighted metering?
10-07-2014, 12:29 PM   #4
Bcrary3's Avatar
As far as I know, I have never really needed to use a flash for most of what I do, so I can't say for sure.
10-07-2014, 02:46 PM   #5
Just1MoreDave's Avatar
The manual does not say it that explicitly, but it does say:
The flash pre-flashes before the actual flash... using the camera 77-segment metering sensor.
That's at the bottom of page 168. It isn't mentioned elsewhere that I could find. I think they mean you should use matrix metering for P-TTL.
I get frustrated quickly with the camera decisions and flash. Instead, I switch to M mode. Set shutter speed to match the subject movement and lens, say 1/30 minimum, 1/180 maximum because that's the camera limit. Aperture for the right depth of field. ISO for the ambient background exposure you want. I have a Pentax AF560FGZ and I allow that to stay in P-TTL auto. If the flash is too bright, the flash has exposure controls and the camera Flash Exposure Compensation controls add to that. It means a few test shots but skips over metering mostly. You need to adjust if your ambient light changes during the shoot.
10-07-2014, 03:00 PM   #6
Lowell Goudge's Avatar
I would use center weighted or spot because the flash will fall off a you move behind the subject leaving it to under expose. I am not sure the multi segment metering will figure out foreground and background for flash
10-07-2014, 04:32 PM   #7
QuoteOriginally posted by Storm Chaser Quote
Some guidance here Balancing Flash and Ambient and here
10-09-2014, 09:16 AM   #8
Thanks again for the help! Been shooting with the center weighted meteringBr and seems to have made a differance, will continue to try different modes. BrookeM thanks, YouTube video has alot of great information! Thanks again(Sorry keys are to small
10-09-2014, 05:14 PM   #9
Good luck on this. Conventional wisdom on this site is to shoot full manual (M-mode with no P-TTL) for off-camera flash. As with the comment above, I am not much of a flash shooter, but have found P-TTL to be frustrating for many subjects.
10-09-2014, 06:19 PM   #10
Thanks Steve, Will Shoot Metz 52 p-ttl and try my new cactus set up on manuel. This gives me some options and so far really like the v6 & rf60.
camera, pentax help, photography, troubleshooting
Scanning Ektar - My Method. Swift1 Film Processing, Scanning, and Darkroom 32 05-07-2015 02:11 PM
People Daughter Brenizer method test konraDarnok Post Your Photos! 7 07-14-2014 08:22 PM
Stitched Panoramas / Brenizer Method Northern Soul Digital Processing, Software, and Printing 26 07-31-2013 01:09 PM
HDR Timelapse test method emtor Photographic Technique 4 10-22-2012 10:07 AM
K-7 CW metering vs Matrix metering raider Pentax DSLR Discussion 11 09-26-2011 02:03 AM
All times are GMT -7. The time now is 10:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
