Hi DDS,
Manfrotto makes something like 5 different QR clamps (thus the RC 2, RC 5, etc designations) The RC 2 is probably the most common. The clamp in the link from psychdoc points to an RC 2 type and is most likely the one that you need.
Before you commit to this, I would suggest that you look into changing the clamp/plate system that you use. The Arca Swiss clamp/plate is easily the closest to a universal QR system, and allows infinitely more versatile and secure connections between the camera/lenses and the tripod head. I started with Manfrotto RC 2 QRs and plates 10 years ago, and soon found that they lacked stability when I started shooting longer/faster telephoto lenses (read big and heavy, and needing increased stability). They also prevented me from easily balancing the camera/lens on a ballhead since the plate does not allow much repositioning leeway front to back. Also, probably irrelevant to you, virtually all gimbal head mfgs have standardized on Arca compatible clamps because they do allow the positional leeway, and balance is everything when using a gimbal head. Manfrotto has essentially admitted this by their relatively recent offering of Arca compatible clamps as options for their heads.
You might consider this all as overkill, and only want the least expensive alternative at this time, but if you plan to use tripods quite a bit, then I'd seriously consider an Arca compatible alternative. Take a look at
Hejnar Photo Store, Serving Your Professional Photography Needs
and
OEC Camera Accessories
to see some of the options currently available, and more are being developed all the time. This is easily the most versatile mounting system available.
Scott
