10-22-2014, 05:43 AM   #16
Oldbayrunner's Avatar
QuoteOriginally posted by Panache Quote
Normally my subjects are landscapes [where focus point isn't often an issue]
Interesting you state that, to my knowledge and experience balancing focus point, hyperfocal distance and aperture is absolutely critical in landscape photography. That is of course if one is trying to achieve sharp to infinity landscapes.
10-22-2014, 06:12 AM   #17
QuoteOriginally posted by Oldbayrunner Quote
Please don't get me wrong, I appreciate your comment and you are correct. I meant that the landscapes I photograph are taken mostly near my cottage in Northern Ontario ....lake, trees, the woods. For my photo album, I'm not trying to take a perfectly balanced image....just a memory!
10-22-2014, 09:12 AM   #18
Thank you to all who gave advise and suggestions. I appreciate the time you took to help.
I'm taking the camera and 35mm lens outside later to do further tests, but I think I might have gotten somewhere with the lens alignment chart. Here's the image I settled on for being the most equally focused, which turned out to be +4 on the AF Fine Adjustment.
I will do some tests with the zoom lens as well, but leaving at +/-0 right now seems to be the best.
PENTAX K-30  Photo
10-22-2014, 01:08 PM   #19
mgvh's Avatar
It was a bit hard to tell, but I thought that the +4 or +6 adjustments looked best. I.e., I concur with your +4 adjustment on the DA 35.
Zooms are a bit trickier, since some of them seem to want different settings at different lengths.
Another way of doing microadjustments that I've found to work well is detailed here.
10-22-2014, 02:31 PM   #20
CarlJF's Avatar
Yes, +4 looks fine with this lens. Don't forget to check at different focusing distances to be sure to this will consistently work.
12-10-2014, 06:39 PM   #21
I figured I should update this issue seeing as it also counts as a contest entry!
I took my gear in to our local Henry's. Long story short, the nice gentleman there told me I'm WAY too fussy and thinks my images are just fine. However, I have to start shooting a little differently [more in the 5-7 aperture range] and to be careful that my shutter speeds aren't too slow., although he was impressed how steady my hand is for my 1/10 to 1/15 second shots!
So, I decided not to send any gear back to Pentax.
Here's hoping!
12-10-2014, 07:06 PM   #22
drypenn's Avatar
Here's hoping!
I think that your images are par for the course. At f/2.4, subject distance of around 35 cm (which is roughly the lens' MFD), I reckon that the depth of field will be around a cm. Too thin. Yes, I agree your images are just fine. It's just the OCD complex in all of us!
af, camera, distance, focus, focus issues, issues, k30, kr, length, pentax, pentax help, photography, shot, steve, surface, system, time, tripod, troubleshooting
Manual focus tips on K30, 18-135mm WR lens jaikumarr18 Pentax K-30 & K-50 22 05-03-2014 04:17 PM
Slow focus 50-200 on K30 allexinwonderland Pentax K-30 & K-50 4 03-12-2014 03:40 PM
K30/k50/k500 - focus assist on external flashes DanGleabols Pentax K-30 & K-50 18 01-17-2014 11:26 AM
DA 55-300 on K30-Intermittent Failure to Focus lawsonstone Pentax K-30 & K-50 6 04-09-2013 06:05 AM
Focus Screen Installation on K30 (Shims etc) godwinaustin Troubleshooting and Beginner Help 2 02-10-2013 03:57 PM
All times are GMT -7. The time now is 10:35 PM. | See also: NikonForums.com, part of our network of photo forums!
