Originally posted by rburgoss Just a thought:
This problem happens ONLY when camera is in vertical position. That means somehow, that whatever "device" is used to detect camera orientation (mercury switch ????) has something to do with this problem. I know it doesn't sound right because exposure shouldn't be affected by camera orientation, but according to tests, IT DOES. At least, the aperture lever is actuated when it shouldn't when camera is vertical.
So, how about disabling camera orientation detection? Don't ask me how to do this, but there is a function to "remember" or not picture orientation.... maybe that's a good place to start.
Thanks for the input, after further testing, I have found that the problem is not limited to vertical mode. It's much more prevalent in vertical mode though. That's why I am now thinking that the mechanism must be harder for it to engage in vertical mode. I wonder if some part of that mechanism is bent, and making it difficult to engage. Like someone tried to use it on a lens that had a stuck aperture and force bent a pin slightly. Who knows though, it could just be that it is a lubricated mechanism that has lost it's lubrication. Since the problem is common and appears not to be related to use.
