10-26-2014, 06:00 PM   #1
K-30 turn-on speed?
The K-30 has been growing on me, but it's noticeably slower to turn on than my K-x. Is there a setting I'm missing? I've tried turning off dust removal and allowing the shutter to fire without the flash, but these didn't seem to have any effect at all (understandably).
10-26-2014, 06:03 PM   #2
It should turn on and release the shutter within a second, but there will be slightly longer delay before you're able to access live view. Is that consistent with your experience?
10-26-2014, 06:48 PM   #3
Thanks Adam, I'm not quite sure. I didn't time it, but I think you can see what I mean here (apologies for the potato quality webcam):
10-26-2014, 07:10 PM   #4
MarkJerling's Avatar
Are you using the same speed memory card in both cameras? Factory or aftermarket batteries?
10-26-2014, 07:14 PM   #5
Just tested it again. No memory card in either, they're both using Eneloops from the same package.
10-26-2014, 07:35 PM   #6
What if you disable Dust removal on startup on both?
10-26-2014, 07:44 PM   #7
I mentioned in my original post that I've tried turning dust removal off and allowing the shutter to release without the flash charged.
10-26-2014, 08:12 PM   #8
Ack, sorry - you did
10-26-2014, 08:28 PM   #9
QuoteOriginally posted by lithedreamer Quote
Interesting. The reason I mention memory card is because the write to card light flashes as the K-30 turns on. I wonder if you should not try it with a card?
10-26-2014, 09:13 PM   #10
Fogel70's Avatar
It's probably because you use a manual lens on K-x. It then ask for focal length used before it "initiates".
Try using a fully featured AF lens on both cameras.
10-26-2014, 11:47 PM   #11
QuoteOriginally posted by Steve.Ledger Quote
No worries.
QuoteOriginally posted by MarkJerling:
Oops, sorry for the confusion. The video I posted had a memory card in the K-30, but I took it out after you mentioned it and tested them again.
QuoteOriginally posted by Fogel70:
I threw my 35 limited on the K-x and my 40 limited on the K-30 with seemingly no difference.
10-27-2014, 08:32 AM   #12
AquaDome's Avatar
The difference seems to be less than 1/3 of a second. Is it actually troublesome, or are you just curious about the internal functionings?
10-27-2014, 01:18 PM   #13
QuoteOriginally posted by AquaDome Quote
It's not that big of a deal, it's just not fast enough anymore to turn on and take pictures while in the car.
camera, k-30, k-30 turn-on, pentax help, photography, troubleshooting
Pentax K-30 Problems. Won't turn on. steezylistic Troubleshooting and Beginner Help 8 07-13-2014 10:45 AM
K-30 Won't Turn Off g026r Troubleshooting and Beginner Help 17 02-04-2014 03:13 PM
My new k-30 wont turn on stewa1cg Pentax K-30 & K-50 5 05-18-2013 03:16 PM
brand-new k-30: does not turn on! kmac Pentax K-30 & K-50 10 04-20-2013 05:55 AM
Plugging in wire into K-30's wireless shutter release port causes LCD to turn off JesterPrime Troubleshooting and Beginner Help 11 12-04-2012 08:52 PM
All times are GMT -7. The time now is 12:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
