11-04-2014, 03:03 PM   #16
Not a Number's Avatar
A non-A lens in Av mode will always shoot wide-open regardless of the aperture ring setting unless the auto aperture lever has been modified. You need to use Manual (M) mode. Provided you have the menus settings for stop-down metering the green button will stop-down the lens and set the shutter speed from the exposure reading through the lens.
Using Older Lenses with the PENTAX K-x | Ricoh Imaging Support
11-05-2014, 01:34 PM   #17
I'd like to thanks you all for your responses to my problem. I'll follow your advice and let you know soon if you have solved my problem. Thanks.
11-08-2014, 02:50 PM   #18
I had to adjust my kx focusing screen by shimming it with scotch tape until the images matched my focus points. Use a ruler held at a 45 degree angle and try focusing on a specific number line with your macro close up and wide open and that will tell you if your screen needs shimming.
11-09-2014, 07:07 AM   #19
I'd like to thank all of you for your responses to my problem of not being able to stop down my lens and getting it to give me the correct exposure. I finally had time to follow the advice given. The key to my problem, as some of you mentioned, was to use the Green Button before pressing the exposure button. When I first did this it still didn't work. I realized that I would have to reprogram the Green Button to "Action in the M Mode-Tv shift". After I did this, pressing the Green Button gave a loud click and the aperture temporarily closed to the selected aperture and set the exposure time. Pressing the exposure button then gave the correct exposure time and a good shot resulted. I was beginning to think that I had purchased a dud lens. Problem solved. Thanks again for your expert advice.
aperture, camera, f/4 100 mm, field, images, lens, macro, mm macro, pentax, pentax help, pentax m f/4, photography, photos, troubleshooting
Compatibility Pentax K 3 and vivitar macro 100 mm 1:3,5 diameter 4,9 mm CJOS Troubleshooting and Beginner Help 6 07-05-2014 11:49 PM
For Sale - Sold: Black Spotmatic SP, 17 f/4 Fisheye, 28 f/3.5, 50 f/1.4, 100 f/4 Macro, 200 f/4 Julie Sold Items 9 08-06-2013 02:40 PM
SMC Pentax-M Macro 100 mm f/4 strange "net" behind the front element Michelek Pentax SLR Lens Discussion 15 09-06-2012 05:59 AM
All times are GMT -7. The time now is 02:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
