Originally posted by dms Someone else can say if I am wrong--but the metering w/ a M42 lens and a (pre A) K lens should be the same--and thus you need to come up with a e.v. correction vs f/stop either way--as both are metering at the taking f/stop--unlike an A lens.
You would think, but that is not the case. Neither M nor Av mode uses the straight meter output. Both use mathematical "splines" to correct for the behavior of the focus screen at various maximum apertures. M mode when no A contacts are detected is supposed to be closer to raw meter output and is generally preferable except that on the K-30 and K-50 the camera requires a conductive base for green button metering to work.
