11-10-2014, 02:03 PM   #1
Camera shake on K-100D ideas?
A few weeks ago my K-100D started shaking when I take any picture. It would make a rattling noise and any picture taken would appear blurry. Turning SR on or off makes no difference. If I press the camera down very hard on a stable surface (such as a table that wont move my tripod isnt stable enough) I can still hear the rattling but the shaking seems to be dampened enough that pictures are not blurry, but I cant use a hard surface every time I take a picture.
Has anyone seen this before? If its something I can fix myself how do I go about fixing it, and if its something that has to be done in the shop how much would it likely to cost to repair it? Thanks very much in advance.
11-10-2014, 02:23 PM   #2
The SR system should normally be faintly audible, but it sounds like it's gone haywire in your case. Might be time to upgrade the body.
11-10-2014, 07:51 PM   #3
Does it feel like the sensor dust removal vibration? I'm surprised you can get a non blurry picture, even with the camera restrained (unless you are running a very fast shutter speed).
It may be worth turning the power up dust removal off in the menu (if set) to see if that makes a difference. Also, have you tried removing the batteries and resetting to factory default settings?
11-10-2014, 08:05 PM   #4
Mikesul's Avatar
Does the K100d have some kind of haptic feedback that may have gone screwy?
11-11-2014, 11:53 AM   #5
schnitzer79's Avatar
try resetting to factory defaults and taking the battery out as suggested. if that doesnt make any difference, the dust removal mechanism might be faulty and goes off with every press of the shutter. try using the timer release or a remote to activate the shutter to see whether the fault is directly linked with the shutter button itself or not.
blurry, camera, k-100d, noise, pentax help, photography, picture, rattling, shaking, surface, troubleshooting
Shake reduction on K-5 going nuts melander Troubleshooting and Beginner Help 2 05-05-2014 11:57 AM
Shake Reduction on K-x Mangoman45 Troubleshooting and Beginner Help 12 08-25-2013 09:03 AM
Camera Club Ideas Gilzuma Pentax K-5 13 07-31-2013 05:17 PM
K 5 - Sensor shake on startup Naim Khan Pentax DSLR Discussion 13 10-25-2010 11:59 PM
K-x shake - camera issue or poor technique? Edwin13 Pentax DSLR Discussion 23 05-21-2010 01:07 AM
All times are GMT -7. The time now is 05:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
