Originally posted by Samwise.Gamgee Hi LensBeginner,
You seem to be right. Below I'm comparing the raw (PEF) and JPEG and the raw file doesn't seem to have this issue. So you're guessing the WB might be going this?
I'll keep reading your link regarding shooting red colour
Looking at them side to side, it looks like the sum of multiple factors...
Saturation and slight overexposure of the more luminous part cause (I believe) clipping in the red channel.
Camera RAW should use the values your camera records as far as WB is concerned... which mode did you use, auto?
It seems more like an oversaturation(and/or overexposure) issue... try paying a visit to the HSL panel in Camera RAW and further reduce Luminance and Saturation with the "Reds" slider, also try adjusting the Hue sliders in the affected colors.
That often does the trick.
Also check that your WB is correct (should be at or around 5500K in daylight).
