Originally posted by Moropo I'm sorry I don't know the correct lingo to explain the situation.
I was taking a picture of someone under a porch and the sun was setting on the back. As a result, the background had a lot of light but it was kind of dark under the porch. I have read on the forum that the camera (K50) takes an average reading of all the light and because of the sun, it thinks there's a lot of light, which there is but not of my subject. How do I tell the camera to "measure" somewhere specifically and not take an average?
The techniques for metering, exposure calculation and fill flash have been explained well in the preceding posts, I'd just like to add that, if you're shooting RAW, you have additional options.
You can expose for the light keeping the ISO low, then push the shadow (only the shadows) when developing the RAW: this results in an increased noise in the shadows, but it would still be tolerable (if you shoot at ISO100, a 3 stop push would result in a result similar to that which would occur when shooting the same scene at ISO800).
You can expose to the right. You can overexpose slightly (0.7 stops) the brightest part of the image, and then both push the shadows (but you'd need to push less than in the first example) and recover the highlights.
Remember that you'll have much more leeway in the shadows than in the highlights.
Or, you could try HDR, provided that the subject is very still and your burst rate quite high (there's still deghosting algorithms for slight movements).
