11-14-2014, 10:29 AM   #16
Marketplace Reseller
dcshooter's Avatar
Well, If you want, I can recover what I can with LR when I get a chance and email them to you later. I so far haven't been able to get anything larger than 40x425. I don't have a K-7, so I don't know what the limits of its image preview size are, but if I find anything larger, I'll let you know.
Correction: 640x425 (typo above)
11-14-2014, 10:53 AM   #17
LensBeginner's Avatar
Yep, I tried as well (IrfanView, ACDSee), and the thumbnail only appears very small and pixelated... every single one of them...
I've read elsewhere that - at least in Canon's raw files - there are like three different thumbnails of varied sizes, just like dcshooter said.
The embedded jpeg preview must be corrupt as well...
Have you already deleted/overwritten the contents on the SD? You could try with another software as other people have suggested.
11-15-2014, 03:21 AM   #18
QuoteOriginally posted by dcshooter Quote
It Would be great if you would recover what is possible.
When I recovered the pictures to my hard drive I saw the small preview pictures and assumed the recovery had gone well. (I intended to process the pictures later on). Therefore The Card has been formatted and used. I am not able to retrieve anything any more...
Again, I really appreciate what you guys are doing for me.
Thanks
11-15-2014, 10:11 PM   #19
Not a Number's Avatar
QuoteOriginally posted by Ivo_Spohr Quote
Have you tried? If you formatted the card in the camera all it does is a "quick format" which just resets the file tables. The actual files don't get overwritten. A program like Photorec examines the data on the memory device an will reconstrunct any files that can be recognized and recovered. Photorec recognized PEF files which many of the other programs do not.
As I stated before, I tested several recovery programs and Photorec does the best job. It is able to recover files from cards that have been quick formatted. It also recovers photos that I deleted over a year ago even though I've filled up the card several times since then.
11-16-2014, 04:25 AM   #20
No Luck, de card has been used and the data is overwritten ( I Thought I had recovered the files....)
11-16-2014, 04:53 AM   #21
If you haven't had luck with photorec or recuva, a free SD card file rescue tool to try from Transcend might be worth a go. Also works on normal disks and SSD's:
Transcend RecovRx
11-16-2014, 05:35 AM   #22
Arjay Bee's Avatar
As others have suggested try Photorec/Testdisk by Christopher Grenier. He has his own website. It is a small program and a free download and is surprisingly clever - may be worth a try as you start to reach the end of your options. Does operate at the DOS level so you need to be comfortable at that command level.
Did a pull of files from a card last week that I had formatted and the process found files that had been taken two or three years ago and several reformats have taken place since then. I know you have corrupted files but give this a try. The testdisk companion program may be able to reconstitute the files... worth a try.
camera, card, data, image, jpeg, line, pef, pentax, pentax help, photography, pictures, recovery of image, troubleshooting
Duracell Class 10.200x ProPhoto SDHC Memory Card Data Recovery Possible? Ricey79 Troubleshooting and Beginner Help 9 12-08-2013 04:51 AM
Need Data recovery guidance ismaelg Digital Processing, Software, and Printing 9 04-27-2013 02:01 AM
SD Card image recovery cats_five Troubleshooting and Beginner Help 9 09-07-2011 12:06 PM
data recovery photog55 Digital Processing, Software, and Printing 4 06-04-2009 02:01 AM
All times are GMT -7. The time now is 08:45 AM. | See also: NikonForums.com, part of our network of photo forums!
