11-15-2014, 09:47 PM   #1
Nakedgun's Avatar
Firmware update help
So, I download the proper update to my Windows 8.1 machine, and there it is in the downloads folder. I can't seem to open it to show the two folders. Any ideas?
11-15-2014, 09:55 PM   #2
clackers's Avatar
"Two folders"?
11-15-2014, 10:02 PM - 1 Like   #3
rRnt's Avatar
Did you download the .exe or the .zip file? The .zip file also unpacks only one file - .bin - that is the file you need to put on the SD card root directory. So I am not following what "two folders" are you referring to.
The Ricoh homepage has pretty good step-by-step instructions, follow them carefully:
Software Downloads : Support & Service | RICOH IMAGING
11-16-2014, 09:24 AM   #4
Nakedgun's Avatar
"Two folders"?
According to the install video, the download has two parts, one folder is the text file, one the bin file.
I can see it as an application in my downloads list but can't figure out how to open it.
11-16-2014, 12:03 PM   #5
MarkJerling's Avatar
QuoteOriginally posted by Nakedgun Quote
The .bin file is to be placed in the root of your memory card that you will insert in your camera. The root means, "not in a folder on the memory card". The .txt file is simply an information file for reading, if you wish. The .txt file is not requred for the install.
Important: Make sure you read the firmware installation instructions carefully. Make sure you have a fully charged, healthy battery in the camera when doing the firmware update. Lastly, do not, under any circumstances, turn off your camera or fiddle with it in any way while the firmware update is in progress.
11-16-2014, 03:21 PM   #6
Mikesul's Avatar
QuoteOriginally posted by MarkJerling Quote
Mark has explained it very well. Firmware updating is very easy and safe if you read, understand and follow the instructions carefully. People only get into trouble when they do not do it as instructed. It sounds more complicated than it is. Just do as Mark says and all will be well. Some people even freshly format the card to be sure the camera only has the bin file to look at.
11-16-2014, 03:42 PM   #7
clackers's Avatar
The exe is a self-extracting archive that will expand into the .bin and readme files.
You talked about a video - where is it?
11-16-2014, 06:07 PM   #8
Nakedgun's Avatar
Here: https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/250893-pentax-ds...ate-guide.html
About one minute in, it says to open the file revealing two items. I'm not understanding how to open the download to reveal these two folders, one being the .bin.
11-16-2014, 08:32 PM   #9
clackers's Avatar
That's a Mac in the video, NakedGun, and they are two files, not folders.
Best follow the instructions on the Ricoh website. Note the cautions, too ... like upgrading your phobe's firmware, it needs to be uninterrupted. :-)
11-16-2014, 09:02 PM   #10
Nakedgun's Avatar
Perhaps I've not been clear.
I've downloaded the update, but, where is the "self-extracting" file with the .bin?
How do I get at it to transfer to an SD card?
11-16-2014, 09:14 PM   #11
clackers's Avatar
The update is the file.
Tell us what its name is.
11-16-2014, 09:30 PM   #12
Nakedgun's Avatar
k5_2s107
11-16-2014, 10:39 PM   #13
Nakedgun's Avatar
QuoteOriginally posted by rRnt Quote
Ni option given to download the .zip file.
What seems to be missing from the instructions is a very important part of the process, namely, how to get at the .bin file and then transfer it to an SD card. The instructions assume one should already know HOW to do this.
---------- Post added 11-16-14 at 09:42 PM ----------
I'm not seeing it expand into the two files as you suggest, it simply shows up in the download listing with all other downloads.
11-16-2014, 11:46 PM   #14
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
Right click the file and chose Extract. This will extract the .bin file. I suggest you extract it to a folder you have made or simply and easier to the desktop.
11-17-2014, 12:35 AM   #15
clackers's Avatar
Yes, it's the second link (Windows/Macintosh) as explained earlier on that page.
Can you right click on the file you downloaded, and confirm that it's 10,134kb in size?
camera, click, desktop, download, downloads, explorer, file, files, name, pentax help, photography, ricoh, troubleshooting
Help! Pentax Q10: Firmware update menu selection TofuTO Pentax Q 3 08-18-2014 05:47 PM
Cant turn on after Firmware update. Need help! Warez Troubleshooting and Beginner Help 14 06-18-2014 05:35 PM
Camera Firmware update help with Mac billy moon Troubleshooting and Beginner Help 25 04-30-2014 08:26 AM
Firmware update HELP billy moon Troubleshooting and Beginner Help 12 03-10-2014 08:42 PM
firmware update...Need Help fnflying Troubleshooting and Beginner Help 9 03-31-2013 10:24 AM
All times are GMT -7. The time now is 09:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
