11-16-2014, 03:32 PM   #1
Mikesul's Avatar
Odd TAV behavior
I like TAV mode on Pentax cameras a lot. However, recently there has been some odd behavior. Mainly it works as expected: A set to 5.6; S set to 500; ISO floating to get proper exposure. However, yesterday a series of photos came our hugely over exposed using FA 31 on the K3. Other photos with the same settings were just fine - no clear pattern. The EXIF shows ISO 100 was used so that should not have been the problem. When I noticed the behavior I retook one of the shots in A mode (same settings) it came out fine, perhaps slightly underexposed. Any thoughts? Oh yes, exposure compensation was at +03 but it has been there for ages without problems.
11-16-2014, 03:36 PM - 1 Like   #2
LensBeginner's Avatar
Maybe there was way too much light for auto ISO to cope?
If you were fully open and with a low enough shutter speed the camera could have tried hard to keep the exposure under control by lowering the ISO, but couldn't go past 100...
Were there noticeable difference in light between the pictures that came out ok and those who didn't?
I see from your number of posts that you're quite an experienced user, but I wanted to try and point out the obvious nonetheless... we're humans after all!
11-16-2014, 04:03 PM   #3
Two comments/questions:
  • ISO always "floats" in TAv mode. That is how it works *
  • Did you have the aperture ring on the FA 31 on the "A" position?
* I generally recommend turning off auto-ISO unless you are a total noob.
11-16-2014, 04:09 PM   #4
ramseybuckeye's Avatar
It does sound like it metered to much light, what metering mode were you using? I've had that happen if I accidentally left in in spot mode when it should have been multi.
11-16-2014, 04:14 PM   #5
aleonx3's Avatar
As rameybuckeye has suggested, could it be that the metering mode is accidentally knocked off to spot mode? I have had similar instance before using my k-5IIs.
11-16-2014, 05:30 PM   #6
Hmmm...that is enough to make Caucasian skin appear white as a snowbank and make lighter tones totally clip to full white.
11-16-2014, 05:33 PM   #7
Mikesul's Avatar
Not really, +03 has minimal effect. By the way, I went out again this afternoon to many of the same places with similar TAV settings without a problem (with and without +03). I will look closely at the EXIFs of the bad shots from yesterday to see if I can find some errant setings.
11-16-2014, 07:24 PM   #8
Class A's Avatar
As LensBeginner pointed out, the use of "ISO 100" could indeed be the clue to the source of your problem.
The K-3 cannot go below ISO 100, so has no means to avoid overexposure in TAV mode after it exhausted this minimal ISO setting.
P.S.: I guess you mean +0.3 EV exposure compensation; +(0)3 EV would indeed be way too much for most scenes.
11-16-2014, 07:58 PM   #9
Mikesul's Avatar
Thanks guys but all of the responses miss the point that it was TAV with a high shutter speed and moderate aperture. It was not set at ISO 100 that is what the camera set. Furthermore when I changed to aperture priority with the same settings, same scene the picture was properly exposed. Anyway, it appears no one has seen the erratic behavior I described so thanks for your help. Yes the 03 was a typo for 0.3.
11-16-2014, 08:28 PM   #10
Class A's Avatar
We did not miss that point.
Exactly.
Do you see that the camera could not get any lower with the ISO?
When you get ISO 100 in TAV mode on a K-3, you either are lucky when the required ISO is ~100 for a good exposure, or it means you get an overexposed image.
I'm not saying that I know what happened and your comment regarding Av mode seems to suggest there is something else going on, but I hope you can see that LensBeginner offered a plausible explanation.
If you were really keen to investigate, you could use PhotoMe (or similar) to read out the metering information for the overexposed photos. If the metering segments show overexposure and the ISO is at 100 in TAV mode, it seems to be unambiguous that the camera just had no chance to avoid the overexposure.
11-16-2014, 08:58 PM   #11
audiobomber's Avatar
I agree with Class A and LensBeginner. The camera couldn't close the aperture or increase shutter speed because you were controlling those. It did what it could by dropping ISO to the minimum. In other words, you forced the camera to overexpose by using aperture and shutter settings that were too bright for ISO 100.
If there's a chance you will be using base ISO in TAv mode, you need to monitor exposure. The settings will flash in the viewfinder to indicate overexposure at the selected settings.
11-16-2014, 10:43 PM   #12
QuoteOriginally posted by LensBeginner Quote
Maybe there was way too much light for auto ISO to cope? If you were fully open and with a low enough shutter speed the camera could have tried hard to keep the exposure under control by lowering the ISO, but couldn't go past 100...
LensBeginner didn't miss the point! @mikesul, you said you had TAv set to 1/500 second at f5.6. If it was a sunny day TAv might have bottomed out at ISO 100 and still overexposed. The exposure settings were probably blinking to warn you that TAv mode couldn't get an acceptable exposure. You might have needed to go with a faster shutter speed.
11-17-2014, 10:16 AM   #13
On my K-3 and my K10D before it, +3 provides 3 stops of additional exposure. I noticed the additional comments and that you meant +1/3 stop which would be very little.
---------- Post added 11-17-14 at 09:20 AM ----------
Yes, that is how TAv works. You set aperture and shutter speed and the camera sets the ISO. There are limits at both the upper and lower end, however.
Was the display blinking (exposure out of range) by any chance?
I don't think there is enough information to determine what is happening here. Please attempt to reproduce and post the photo with all exif intact (use in-camera JPEG).
11-17-2014, 11:16 AM   #14
I think what happened is perfectly clear. There have been several threads like this, where people don't realize that the camera will not override the aperture of shutter speed settings in TAv mode. If the settings require less than ISO 100, the camera will overexpose.
What is the purpose of specifying in-camera jpegs? The exposure will be the same, whether raw or jpeg.
11-17-2014, 11:34 AM   #15
QuoteOriginally posted by audiobomber Quote
The purpose is that exif is often stripped on export after processing RAW. This happens all the time. I suggested a photo with exif because the problem description was vague.
I agree that it is extremely probable that the problem is simply overrunning the exposure capabilities of the camera. That is why I asked if the display was blinking. There are at least two or three problem threads a month where there is a complaint of over/underexposure and the blinking display had been ignored.
Translation: I think you, along with lensbeginner and Class A, are very probably correct, sorry you did not pick that up from my previous comment.
behavior, camera, exposure, iso, mode, pentax help, photography, photos, post, settings, steve, tav, troubleshooting
Forum contest and odd forum behavior tvdtvdtvd Site Suggestions and Help 3 11-03-2014 03:30 PM
crazy shutter behavior kona49 Troubleshooting and Beginner Help 7 05-11-2014 08:22 AM
Error Odd Quick-Reply Behavior Parallax Site Suggestions and Help 13 09-17-2011 03:41 PM
Odd Tamron Lens Behavior - Advice Please? krs Pentax SLR Lens Discussion 10 10-21-2009 11:05 AM
Odd behavior THAN THE SWORD Pentax DSLR Discussion 2 09-10-2009 05:36 AM
All times are GMT -7. The time now is 01:50 AM. | See also: NikonForums.com, part of our network of photo forums!
