Show Printable Version 4 Likes Search this Thread
11-25-2014, 07:32 AM   #31
audiobomber's Avatar
Wombat, what model of flash bracket is that? I have a bracket which is great for a DSLR, but a bit large for my a6000.
11-25-2014, 07:52 AM   #32
Otis Memorial Pentaxian
QuoteOriginally posted by audiobomber Quote
I had not heard of that, but then I've never used Green mode.
The *ist DS doesn't have a "green" position on the mode dial. Instead one half of the dial is used for Auto Pict and various scene modes and "no flash". The other half has P, Av, Tv, M, and B.
QuoteOriginally posted by wombat2go Quote
The histograms of both photos ( close ups of a stainless coffee pot) were almost the same.
That is interesting. Thanks for doing the comparison.
I don't have a *ist DS to play with and was going from the description from the manual. The full-power behavior on manual raise with in Auto Pict mode is explicitly stated while the P-TTL on auto-raise was only implied. I found the manual to be very confusing regarding flash usage. Thanks for your contributions.
11-25-2014, 08:32 AM   #33
Yes. The original ist-ds manual here is moth eaten and dog eared on the pages associated with flash.
I made some extra notes, and I still find some more tricks occasionally.
Thse were taken with the ist ds and the AF500FTZ in TTL mode with the head rotated.
PENTAX *ist DS  Photo
11-25-2014, 09:51 AM   #34
That's so cool. Thanks for the notebook tips! I feel like I'm seeing some ancient scrolls from the distant past....from back in the days when CCD was king and not CMOS! <haha>
Seriously, I'm going to save this thread and maybe do some experimenting when I get some time off from work during the Holidays over the next month or so.
Thank you, and thank everybody that has helped - even if some of it was a little overwhelming and over my head. It just came at me kind of fast and I've not had time to study and let it sink in. But it will.
Scott
11-25-2014, 05:12 PM   #35
Same for a K-m. The manually popped flash in "green mode" (auto pict) changed shutter speed to 1/45 and aperture remains same. This is the same behavior as with auto-pop.
I did have one occasion that auto-pop did not change shutter speed and became over exposure, but does change if I popped it manually. It stay with that behavior even after few camera off/on cycle. It went away after I changed to force flash from menu and back to auto flash. I think it was a firmware problem.
11-25-2014, 06:00 PM - 1 Like   #36
It is an LPL brand, made of pressed steel with molded plastic grip, purchased about 1982
There are a few used ones out there:
Vintage LPL Flash Handle Camera Grip Bracket Professional Good Condition ::. www.DiaplousFoto.com
I modified mine to remove the cold shoe and replace by a 1/4 hole so I can mount hot shoes on it to adapt the pc cable to the Takumar 6x7 and the Pentax off-camera-shoe adaptors + cables ( costly) for the Pentax DSLRS and flashes..
11-25-2014, 07:37 PM   #37
Thanks Wombat, I just bought one.
11-25-2014, 08:12 PM - 1 Like   #38
Brooke Meyer
Guest
QuoteOriginally posted by Astronomersmith Quote
Any suggestions or quick, easy fixes? Any reference or website or something that could help me take better flash photography? Scott
No easy fixes, you have to invest some time on learning. Here is a good, free website that explains: http://neilvn.com/tangents/tutorial-bounce-flash-photography/
A $50 Yongnou 560 flash and half a $1 piece of black foam can do quite a lot. Indoor events, the "black foamy thing" is the only way I shoot anymore.
Skip the brackets, get a hot shoe flash and a piece of foam fastened with a girls hairband. And learn how flash exposure works. It's not difficult.
11-25-2014, 09:44 PM   #39
Brooke, That is a beautifully exposed photo.
I see it is with a K-5 at ISO3200 and at f/11
The O/P (and me) use ist ds which in my experience is quite OK up to ISO400 and a bit ragged at ISO800.
So the ist ds will need a fair bit more direct illumination from the flash in a photo like that. ??
11-25-2014, 11:40 PM   #40
Brooke Meyer
Guest
Brooke, That is a beautifully exposed photo. I see it is with a K-5 at ISO3200 and at f/11. The O/P (and me) use ist ds which in my experience is quite OK up to ISO400 and a bit ragged at ISO800. So the ist ds will need a fair bit more direct illumination from the flash in a photo like that. ??
Went to K5's in 2011 for low light capability so I don't really think about it. Shooting dance in theater, I start at ISO 3200.
My example was just something I knew was done with a flagged, bounced flash. I probably went to f11 for ambient, with winter sun pouring in, big dynamic range. Doesn't really matter, flash exposures are always 2 exposures, ambient & flash so controlling the flash with bounce & direction makes the difference. In my example, I had a high white ceiling, all I wanted was fill without direct flash on the violinist.
Here's an everyday example. Wife got birthday flowers and wanted photo to e-mail daughter. Back lit on dining room table, 8 ft white ceiling, Yongnou 560 at 1/4 or 1/2 power, black foamy thing around flash, light bounced off ceiling. f8, 1/125 for ambient and ISO 400. I could've dragged the shutter and boosted flash power and gone to ISO 200 easy or gone to 5.6 or both and gone to ISO 100. .
11-26-2014, 08:14 AM   #41
Hey Brooke, I watched that video and tried the Foamy Thing ( actually just using black craft paper till I get some foam)
It is a winner, the photo here is more certainly evenly exposed than than the ones in my post #27 above.
It does take some cast from the ceiling color here, and using the ist-ds at iso 200 with the SMC Pentax-M 1:3.5 28mm at f/5.6, the AF500FTZ had to be at full power in manual.
(The dull morning light in the room is only EV4 or so)
The AF500FTZ has the swivel necessary to use this method without a flash bracket (The AF 360FGZ does not have a swivel)
The AF500FTZ is compatible with the ist ds but it only has TTL mode so it is not very usable on the later Pentax dslrs.
11-26-2014, 08:46 AM   #42
Brooke Meyer
Guest
Hey Brooke, I watched that video and tried the Foamy Thing ( actually just using black craft paper till I get some foam). It is a winner, the photo here is more certainly evenly exposed than than the ones in my post #27 above.
The foam is $1 at Michael's, make you two pieces. All I've ever shot are DNGs so color cast is pretty easy to fix, my attempt below..
I started out with a pair of Pentax 540's, 1 new and i used. Just sent both to KEH for repair. One fixed for free and one not worth fixing. Used 540's at KEH.com are about $218, includes their std 6 month warranty.
A good and cheap alternative is $50 to $70 for Yongnou 560, 560 II or 560 III. Tilt, swivel, zoom, power adjust, very good recharge time and throw away cheap. I have 3, use on tripod as light stand for outdoor sessions, bare or through an umbrella. The product shot is bare flash, Santa ( which I'll shoot again on Dec 6th) is through an umbrella. Wireless Triggers are $20 to $30.
11-26-2014, 09:42 AM   #43
QuoteOriginally posted by cali92rs Quote
Bounce flash...bounce flash...bounce flash
It's the easiest way to soften the light and make your pictures look natural (as well as allow you to shoot at a much lower ISO).
But as venom mentioned above, that requires you to buy an external flash.
Yep... As a rule, direct flash looks lousy because it's a small light source. As a rule, the bigger the light source, the better your photo will look. Bouncing the flash from the ceiling or wall makes the light source bigger, which is the key to eliminating harsh shadows. I'd buy an external bounce/swivel flash.
11-26-2014, 09:48 AM   #44
LensBeginner's Avatar
QuoteOriginally posted by Brooke Meyer Quote
That's a nice tip, and a terrific picture with an interesting angle... were you on a chair or something?
11-26-2014, 09:56 AM   #45
QuoteOriginally posted by GibbyTheMole Quote
I've often heard that, but it does not account for the positive benefits of a diffuser and/or flash bracket. Diffused flash looks more natural than bare flash. A flash bracket hides ugly shadows behind the subject and eliminates red-eye.
ambient, auto, bit, bracket, camera, ceiling, ds, exposures, flash, flash pictures, iso, light, pentax help, people, photo, photography, picture, scott, subjects, suggestions, terrible, thanks, time, troubleshooting, try
Abstract IR - Terrible gradient blending in the sky willskywalker93 Photo Critique 17 10-10-2014 09:39 AM
Pentax marketing is terrible. Mr_Canuck Photographic Industry and Professionals 10 06-10-2013 06:44 PM
Terrible noise! pugsypoogirl Pentax K-5 & K-5 II 31 02-20-2013 04:06 PM
Nature Even in terrible light... gjtoth Photo Critique 6 02-17-2013 10:27 PM
How do I fix these terrible pictures? robdrobd Troubleshooting and Beginner Help 28 01-07-2011 03:21 PM
All times are GMT -7. The time now is 04:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
