12-06-2014, 06:50 PM - 1 Like   #61
eddie1960's Avatar
On board set pttl, set -2/3 to -1 ev use an old white plastic film cannister with a slit in it as a diffuser. expose for the room -1.5-2 ev with a slower shutter (the flash will freeze action) (you can buy pop up diffuasers but if you have any opague white plasti you can fit it works)
Buy a proper flash, if mounted on the camera bounce it off the wall behind you or a wall to the side (don't bounce straight up it's going to be flat bounced from the side or backwards works. I still crank back the flash -2/3to -1ev myself and expose for the room -1 to -2 ev
this was bounced off a side wall with a warmong stofen diffuser 2nd curtain sync at a slower shutter speed and wide open @ f 1.2 using a ttl set up (Fuji has as por a flash system as anyone the ds may actually be better with an old af530
next up i need a bracket and ttl cord to make the setup more flexible but creative bounce and exposure works well
12-06-2014, 06:57 PM   #62
eddie1960's Avatar
this is using a diffuser on the on board flash (the film cannister idea) this is a quick export sooc jpg
12-06-2014, 08:23 PM   #63
eddie1960's Avatar
if you do grab a compatible pttl flash for the camera read this guys tips they are excellent (even if he isn't always his tips are great)
http://neilvn.com/tangents/flash-photography-techniques/
---------- Post added 6th Dec 2014 at 22:24 ----------
QuoteOriginally posted by Brooke Meyer Quote
No easy fixes, you have to invest some time on learning. Here is a good, free website that explains: http://neilvn.com/tangents/tutorial-bounce-flash-photography/
A $50 Yongnou 560 flash and half a $1 piece of black foam can do quite a lot. Indoor events, the "black foamy thing" is the only way I shoot anymore.
Skip the brackets, get a hot shoe flash and a piece of foam fastened with a girls hairband. And learn how flash exposure works. It's not difficult.
ha i was posting the same info - good site
ambient, auto, bit, bracket, camera, ceiling, ds, exposures, flash, flash pictures, iso, light, pentax help, people, photo, photography, picture, scott, subjects, suggestions, terrible, thanks, time, troubleshooting, try
Abstract IR - Terrible gradient blending in the sky willskywalker93 Photo Critique 17 10-10-2014 09:39 AM
Pentax marketing is terrible. Mr_Canuck Photographic Industry and Professionals 10 06-10-2013 06:44 PM
Terrible noise! pugsypoogirl Pentax K-5 31 02-20-2013 04:06 PM
Nature Even in terrible light... gjtoth Photo Critique 6 02-17-2013 10:27 PM
How do I fix these terrible pictures? robdrobd Troubleshooting and Beginner Help 28 01-07-2011 03:21 PM
All times are GMT -7. The time now is 09:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
