11-23-2014, 05:55 PM   #1
K 3 problem
M K3 started saving each shot as separate red, green blue and purple frames. What on earth has happened? Did I change some setting? Is this a sensor problem? I don't have any filters turned on. I was saving in jpeg. Never had this problem before today. I couldn't find anything like this in the manual. Please help!
11-23-2014, 05:59 PM   #2
Could be a corrupt SD card. Have you tried formatting it?
11-23-2014, 06:43 PM   #3
jatrax's Avatar
Is this on the camera lcd or on the computer?
11-23-2014, 07:48 PM   #4
TimesShadow's Avatar
Start with this... If you see the same problem on your computer and camera, its definitely the file or card. So your next ate would be to try a different card. If you still have it, reset your camera to defaults. Are you using a third party battery? Try your original. If still having it, time to consider contacting tech support/warranty process and/or upgrade or reflash your firmware. Since you may have a warranty issue, I'd recommend fooling with your firmware only under the instruction of tech support so if it gets bricked, it's because they recommended it.
11-23-2014, 08:27 PM   #5
Mikesul's Avatar
Please post one of your photos so we have a better idea of what the pictures look like. This is not normal.
11-23-2014, 10:12 PM   #6
rburgoss's Avatar
This is happening most likely at computer level, from the used software to open the files.
Somehow, your software is opening your files as inverted 32 bit (8 bit/channel)- separate channels. As reference, this mode is sometimes needed to prepare images for color separations for commercial printing.
Red is the inversion of CYAN
Green is the inversion of MAGENTA
Blue is thd inversion of YELLOW
The purple channel is a composite of the needed BLACK spot to increase printed contrast on every place the CMY values ar similar (gray spot component).
This could happen at computer level if your software can be set to "open as separate inverted channels". Sometimes it may come from a software/hardware bug (video analog/digital conversion) and in very rare cases, as a source bug (camera).
First, try opening file in different commputer, or in same computer with different software. You can pinpoint software or computer this way. If problem persists, means camera possibly needs a resetting or firmware reflashing.
Let us know your findings.
camera, k3, pentax help, photography, sensor, troubleshooting
Battery Grip on K-3 and K-5 II Problem morph00 Troubleshooting and Beginner Help 11 02-03-2015 01:55 AM
K-3 auto focus problem DAKS Pentax K-3 & K-3 II 23 11-11-2014 03:03 AM
K-3 freeze problem Gerdup Troubleshooting and Beginner Help 17 07-17-2014 06:18 AM
New K-3 owner-problem burb Pentax K-3 & K-3 II 32 12-15-2013 12:20 PM
First K-3 Problem Azzy Pentax K-3 & K-3 II 21 11-03-2013 09:58 AM
All times are GMT -7. The time now is 09:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
